Question about Tylo SUPER SPORT-U8 Heater 8 kW
The shaft broke on my timer. I need to replace the timer. Where do I go to order one of these. Thanks Sonny
Posted by f6rider99 on
Dan Steele
    New Friend:
Call Saunatec Inc. at 888-780-4427 and ask for tech support. We have these in stock.
Dan
Technical Support Supervisor
Posted on Oct 13, 2011
I have a GE top load washer model #WJRR4170GWW. When I attempted to change the load size from large to super, the knob broke and came off the control panel. Now there is just a hole on the control...
themobilian_130.jpgThe new part has a clip in it that holds it to the shaft of the timer. Installing it is so easy. Just slip the new knob on the shaft of the timer. IF the shaft is still on the timer. Did you mean the shaft came out of the timer? In that case you would need a new timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2010 | GE Washing Machines
Cannot set Control dial for wash cycle. Knob will not move indicator dial. Rotating without engaging indicator. Thanks
Pull the center knob strait off. I suspect the center shaft of the knob is broken. If it is order a new knob but before replacing it make sure the shaft on the timer does not have a metal sleeve from the knob remaining on the timer shaft. Temporarily you can try to use needle nose pliers to turn the shaft to see if the washer works.
Aug 21, 2010 | Washing Machines
The timing knob on my dryer wouldn't turn, it would just spin without selecting a setting so I pulled the knob off and tried using pliers to turn the plastic shaft to select a setting. It worked a couple...
Both the timer and the knob is replaceable.
Locate the model number of the unit. Here's info on how to find it:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+86673100&pathTaken=partSearch
You can get the timer and the knob from www.searspartsdirect.com or call 1-800-252-1698.
Once you have the part, remove the screws from the back of the control panel, removing the back cover. From there you should see the timer. It will either have one wiring harness or many wires attached to the timer. INSURE UNIT IS UNPLUGGED WITH NO POWER TO IT. If there is a harness, unplug the harness. The timer will be held in place either by a couple screws on the front of the control panel that is normally hidden by the knob AND/OR a screw INSIDE the control panel at the timer. There could also be a plastic tab holding the timer in place. Raise this tab and turn timer until it is free. Remove timer and put new timer in place. Fit harness onto timer.
If there are many wires attached to the old timer, I would hold the new timer in my hand and transfer the wires one-by-one to insure you get the right wires on the right terminal tab. Once wires are transferred, remove old timer and put new timer in place.
At this point. put new knob on the timer on the front of the control panel. Plug unit in, stay clear of exposed wiring, and test dryer. If it works, replace back cover and you are done.
If it doesn't work, further troubleshooting will be needed and Ill need the make and model number.
Hope this helps. Please take a minute to give a testimonial if I've help you.
Thanks, G
Aug 04, 2010 | Dryers
The shaft to my 3300 bounty hunter metal detector broke. Can I order a new one?
if there is a customer service number id try there if not, try replaceing it with the pole of a cheaper detector
Oct 31, 2009 | Electronics - Others
Kick start broke and case broke
the kick start broke or did the shaft that the kick start bolts to?, if the shaft broke, you will need to remove the case and replace the shaft. as for the case, depends on how bad it broke, some people can weld alum. but i would buy a new case. and then install kick start on new shaft
Sep 25, 2009 | 2004 kawasaki KLX 125
Sunbeam Rocket Grill - knob broke - where can I find a replacement?
I contacted Sunbeam at (866) 588-1081. They are supposed to send a replacement timer knob in two weeks at no charge.
Mar 03, 2009 | Kitchen Appliances - Others
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
The timer knob broke - can't find replacement
Assuming it has broken on the shaft then you could pry the broken bit off the shaft and take the knob and broken piece to your domestic appliance parts stockist. The shafts are usually a standard size and there might be a similar knob that you could replace it with.
Oct 02, 2007 | Solis Maestro Electric Burr Grinder
Tylo SUPER SPORT-U8  Heater 8 kW Logo
177 people viewed this question
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
