Question about Moyer Diebel 401HT Dishwasher
Moyer diebel 401 ht not reaching temperature ????
Moyer diebel 401 ht dishwasher water not hot
    New Friend:
  • 40 Answers
Could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Posted on Jan 25, 2012
2 Suggested Answers
Brian Watters
  • 13 Answers
SOURCE: We have Moyer Diebel model
The drain flap/mechanism could be faulty or the hose in the back does not have a high enough loop and is siphoning back into the dishwasher.
Posted on Apr 22, 2011
Dickson LAU
  • 86 Answers
SOURCE: Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is [email protected] God Bless Have a nice day, Dickson
Posted on Jul 02, 2009
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/phillip_77d32603f8052503
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
I have a 501 ht moyer diebel undercounter dish washer that doesnt drain all the way
Could be a clogged drain line, a failing pump or even the dishwasher not level
Jan 16, 2013 | Dishwashers
Moyer deibl 401 ht overheaing
possibly the thermostat needs replacing
Jan 04, 2012 | Moyer Diebel 401HT Dishwasher
J have a moyer diebel 500 HT i need a picture of the tank were the heater elements go ..i had a repair guy com in to wire the heaters up because they shorted out and he wired them wrong if you can help me...
Hello there
The 500HT machine is very old one. Turn off the power first. To get to the elements you have to get the control box off first so you can get to take off the elements cover , now you can see the elements.
If the system have been wired wrong and short circuit it. the temperature control may have to be change too. I would change the two elements and the temperature control and the hi ltd control all together at the same time so you know that system have no problem anymore. All the best Dickson
May 02, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Model# 501 ht mb HHH message in both wash and rinse temp display at different intervals,extreamly hot. cant find manual, washer installed 2 yrs ago not 1 problem untill yoday
Possibly the booster thermostat needs replacing. Expansion of the water in booster enters the wash tank when boiling showing HHH on both displays.
Mar 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Need to purchace a booster tank for 401 ht moyer debel where do i look.
A service man might have a used one kicking around. Or buy new.
Feb 26, 2011 | Moyer Diebel 401HT Dishwasher
Stuck in wash cycle... timer bad?
Possibly the booster is not reaching proper temperature.
Sep 06, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Moyer diebel model 301HT - water does not drain out
Could be the drain hose is kinked or partially blocked
May 12, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Dishwashers Logo
520 people viewed this question
Top Moyer Diebel Dishwashers Experts
GPEC
Level 1 Expert
Phillip Cushnie
Phillip Cushnie
Level 1 Expert
Tom Chichester
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
