Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Prints in blue and green ; all ink cartridges are
Prints in blue and green ; all ink cartridges are full
Posted by dahcota on
dwhollrah
    Problem Solver:
  • 12 Answers
If your ink cartridges are all full then the print head which houses the ink cartridges is probably plugged, meaning the nozzels in the print head that spray the ink onto the paper are plugged by dried ink or debris. By flipping the gray lever up on the printer carriage you can reach into the carriage and pull the print head out...after removing the ink cartridges of course. This removal can be a bit awkward but it will come out with a little wiggling. When removed you can flip the print head over and view the ink nozzles. these nozzles will need to be soaked in warm water. Stand the print head in a saucer or shallow bowl and pour a small amount of warm water in the saucer or bowl. Let it sit in about an eight inch of water for 20 minutes and then set it out on a pile of paper towels. You'll see a lot of color soak into the towels. Repeat this process until no more pigment drains out. Don't get water up on the contact pad on the rear of the print head. Dry assembly with towels and you could blow dry it also with a hair drier...but not too hot. Reinstall and run 2 cleaning cycles. The degree of the plugging and the age of the print head will determine the effectiveness of this maintenance. If you are not successful the first time try the cleaning again. Otherwise you can order a new printhead for around $50. I have done both for my MP730 successfully. Hope this helps!!
Posted on Oct 11, 2009
Mohini Hersom
  • 41 Answers
Dear Dahcota; If it has a single color cartridge, there are three components inside the cartridge-red, green, blue, and all colors are a superimposition of these 3 basic colours RGB in different proportions. It looks like the red component has run dry. So, what you get is the color without the red component. If its showing all cartridges as being full, sometimes these levels shown are inaccurate. Try changing the entire color cartrigde or red component, then see if you still have the same problem. What I am not sure is if the red cartridge is a separate entity . If the red is separate, and changing it does not improve things, the connection in the printer might be faulty. Go to www.hp.com and browse for the correct make ask them online there, It should really be okay, once you have replaced the red or entire color cartridge is it is a single unit with all 3 colours
2 Related Answers
Anonymous
  • 352 Answers
SOURCE: Cyan ink cartridge is flashing, only prints in blue.
Hi cmwierson, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: Black ink won't print.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
My ink cartridges are full but when I print something it does not print blue or green. What can I do?
Assuming you've recently changed your ink cartridges the first thing you can try is seeing if you've placed the cartridges properly (did you remove all the plastic covering the cartridge so the ink can flow into the printer?)
If you haven't actually changed your cartridges in a while the printer might be registering the wrong ink levels. This will result in your cartridges not being as full as you think.
Another thing you could try is checking the printer head for anything that's keeping the ink from flowing. By printer head I mean the thingy that houses your ink cartridges. Perhaps there's some old dried up ink blocking the way?
Mar 12, 2015 | Office Equipment & Supplies
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Green is printing blue
If Green is printing as blue, you are not getting any yellow ink. Blue + Yellow make Green.
Please check to make sure you are not out of ink in the yellow cartridge and that the nozzles are clean.
Oct 27, 2009 | Dell A940 All-In-One InkJet Printer
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
144 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
