Question about HP Pavilion dv6000z Notebook
I press the power button, the computer beeps 4 times and stops
I press the power button, the power button then starts to slowly flashe and the computer beeps 4 times and then stops doing anything. The hard drive does not spin up.
Posted by markwe on
  • markwe Oct 11, 2009
    Thanks, I did removed the battery and just used the plug in adapter with the same affect.
Onifade Adewunmi
    President:
  • 2,004 Answers
Please check the battery. You might have to replace the battery bcos it definately gone bad already.
Posted on Oct 11, 2009
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Tip
Dell Vostro 1000 Bios - Flash Failure
I attempted to update the BIOS on my Vostro 1000 to cure the bad battery message. My original BIOS was 2.6.1 and I intended to update to 2.6.3.
I could not flash under Windows 7 so I installed XP but the flash failed half way through.and the computer did not power up again. All that happened after I pressed the power switch was the light came on and the CD drive shuffled a couple of times. No screen illumination.
Various posts were scanned but no solution found until my buddie came up with the following sequence.
Get the file posted in this link on a computer running XP
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
. A. Remove Battery
. B Depress power button for 10-15 sec.
7. Insert USB drive into USB port of the Dell.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a single beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
This worked for me and as a bonus I do not have the battery error message anymore.
on Apr 06, 2011 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
HP BEEPS WHEN STARTS UP AND WONT RUN
This is a warning that some piece of hardware is not working. You may want to check fans making sure that they are functioning to keep your devices cooled down. If these stop working you may have burned out the CPU chip. Most likely it is a memory stick or a mouse or keyboard that may not be connected properly make sure that everything is connected and in their right ports. What I do to find this out what it is I isolate devices to see if the beeping with stop or it will start the BIOS. I start with the mouse then keyboard then anything that is plugged in externally I unplug one at a time powering up each time I undo a device if the beeping stops then that is the problem device. You can also go in the computer case and undo the hard drive and one stick of memory one by one. If it continues and you have illuminated just about everything then it may be the system board itself.
More than likely it is a memory chip you know it is not the power supply because it starts up. If you do not want to do this process of illumination most folks do not. I suggest you take it in and let the people who can best fix this do the job. They can determine the issue rather quickly by reading the codes on the BIOS flash page when the computer first starts up try and see what it is saying when it comes on if you get the BIOS at least to flash information for you. The machine will say keyboard not installed or no hard drive found. Also you can go back by removing any devices that you just replaced or added this could also be the cause.
Last ditch effort unplug the computer from the power outlet push in the power button hold for about 2-3 seconds you will see a flash. Now plug the computer back in the power outlet then restart the computer this sets your computer back to default settings and loads devices again. Often times this can resolve problems more than likely with beeping it will be a hardware issue. I hope that this shed some light on the issue for you, thanks for using FixYa! John
Apr 08, 2011 | HP Pentium 4 (p5663-69001)
I installed Dell Vostro 1000 System BIOS, v.2.6.1, A04 on myDell Vostro 1000. When it was finished the screen went black and it won't start. Now what? is the computer ruined?
Yep I did the same. Finally recovered using the link shown below.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
10. Continue holding END until USB drive begins to flash and a beep is heard.
Good luck Dean/Steve
Mar 11, 2011 | Computers & Internet
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
CANNOT START THE CORRECT HARD DISK WAS NOT FOUND
To solve this problem follow these steps :
Step 1. Turn your PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then beep once more and turn off into standby again. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then 5 seconds later beep again and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect your controller via USB and press the PS button. Do this and then continue to the next step.
Step 5. The recovery menu will load. Select 3 "Restore File System". This will rewrite the hard drive system and hopefully get your PS3 working again. You shouldn't lose any save game data but that is not guaranteed. Ignore any messages about the hard drive being corrupt.
If the above method does not work try steps 1-4 again but select option 4 from the recovery menu. If that doesn't work as a last resort select option 5. Selecting this option WILL erase your data!
I hope this helps and thank you for using FixYa
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Corrupt hardhrive msg comes up and can not do anything
Follow these steps to try and bring your hard drive back to life :-
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off please let go of the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps let go of the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
Hope this helps and thank you for using FixYa
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
HP Pavilion dv6000z Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
