The electric outlet box in the ceiling (is there only one black and one white wire to be connected)? If so, you have to connect the black and blue wires from the fan to the black house wire. If you know this is already done, you next have to check the connetor from the light assembly to the connector of the fan unit ( that these coneectors are properly fitted). If this is ok , then the final item to check would be the pullchian switch for the light. Over-ride this switch (jump its connection) to see if light works, or take the light unit and apply ellectric to itfrom an extension cord (after you remove it from fan unit). Then you will know if wire connections within light are ok. All this assumes ther fan is not controlled by electronic remote control. If you have a remote control, thenit could be the circuit broard within the fan that sends a signal to the light. Good Luck, Macgivor
