Hi
Thanks for using FixYa. The TV
will automatically turn itself off after approximately 15minutes if it is tuned
to a vacant channel or a station that completes its broadcast for the day. This
feature does not work in VIDEO mode. If the power is cut off while you are viewing the TV,
the last mode memory feature will turn the TV on
automatically when the power is re supplied. If the power is going
to be off for a long time or you are going to be away from your TV,
unplug the power cord to prevent the TV from turning on in your
absence. You’ll also need to check the swollen/bulged capacitors
on the power supply board inside the TV. The TV itself turned it off in the
case of any bad capacitors or overheating with the help of built-in sensors. You’ll
need to replace the swollen/bulged capacitors. Please also check the power from
and to the TV.
Please do rate the solution and
revert for further assistance.
Thanks
Rylee
