Macally IceCam Personal Web Camera Logo
Question about Macally IceCam Personal Web Camera
Macally icecam shows user on screen but not visible to friend when chatting .......driver shows as installed
Posted by kevinbushnel on
Anonymous
    Genius:
  • 3,422 Answers
HI,
Please reinstall you camera software and after that also reinstall the messenger software which you are using to chat with your friend.This should fix the issue.
Let me know if you need any more help.
Thank you
Posted on Oct 11, 2009
1helpful
2answers
I can't install the Icecam because of Finder applications
Are you running OSX 10.4? Not supported yet...
  • Mac OS 9.2, Mac OS 10.2, Mac OS 10.3
  • Elsewise call MacAlly support or Apple.
    ICECAM install problem
    You may try to find out where the fault is, one thing to know is use another the same driver and install it on your PC. If it installed then your previous driver is faulty, if it poses the same problem you have the problem on your PC. Try first using another same driver.
    1helpful
    How to install an icecam 2 in a Mac G4 with 1.1 USB port
    Drivers can be found here: http://www.macally.com/EN/Techsupport/Drivers.asp
    If you want to use the camera with iChat you will need the third party software called iUSBcam found here: http://www.ecamm.com/mac/iusbcam/
    Side note, I have yet to get this camera to work in OSX 10.3.9, so tread lightly.
    2answers
    Macally icecam webcam
    Hi.
    Could try here, no knowing the quality though.
    http://www.welovemacs.com/icecam.html
    Ice Cam will not work
    1. Please make sure you install the software first before you plug the iceCam.
    2. You may try it on another built-in USB port
    3. If still not working, the iceCam may defective.
    Problem with macally icecam
    1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
    2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
    A new Save window will pop up, set up the filename and location and click SAVE button.
    Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
    If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
    2answers
    Icecam set up/installation problems
    Hello all, we supply Macally Icecams through our company and have done so for many years.
    The camera works absolutely fine with Skype.
    Unfortunately Skype do not make it easy for people to understand how, so we wrote a user friendly blog about it and it can be viewed here:
    http://blogs.ebay.com/skinnywolf_online/entry/Webcams-for-Mac-Users-The-best-VoIP-Interfaces-t/_W0QQidZ189277018
    Simply copy and paste the above link into your browser to find the easy set up procedure.
    Hope this helps
    1helpful
    2answers
    IceCam on Mac OS 10.4.8
    I have a mac book with a & web can not been seen in system preferences
    Top Macally Computers & Internet Experts
    Paul Bade
    Mike
    Muzahura Frank
    Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
