Hi,i have a hp w2007 lcd monitor,the problem is that i'm constantly getting the main menu display and osd lockout appearing on the srceen for no reason -- what does this mean and how do I get stop this from popping up?
Once you realize that resetting it doesn't work (as I did ) take it apart. This instruction is for an hp w2007 only! It's the one I just fixed. Remove the three screws holding the base on. The one in the middle is hard to see because it's in a hole but readily accessible. Remove the black back cover by inserting a skinny screwdriver between it and the gray housing. Start in the middle on any of the four corners.Pry it up and work your way to the corners. At the corners pry up with more force and the plastic tabs will snap off. Trust me, just do it!! Once you have snapped the plastic tab at all four corners the back will lift right off. locate the three small wires that go into the menu, -, +, select switches. Cut the three wires and tape them off separately. Do this so they can't touch the case or each other. Do to the wires that are going back toward the monitor! The ones going to the switch do not need to be taped. The switches are now dead. Is that clear? Cut the wires going to the switch and tape the cut ends that go back to the monitor. You will no longer be able to manually adjust anything but I never used the adjustments anyhow. The PC will take care of it for you. I did this 8 hours ago and it's still working perfect! Before I made the fix I was getting OSD Lockout, no input signal, it was scrolling through the menu and the screen was going blank every 5 minutes!! It will work!!!
SOURCE: problem on hp monitor
I have a Dell E171FPB monitor that had the
same problem with the Main Menu coming up and I thought I would tell you
what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and
slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back
cover.
At the bottom of the monitor case, there is a small circuit board the
holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second
switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence
while holding the switch with a pair of needle nose pliers. I had to
rotate this process from one prong to the other while all the time
applying slight pulling pressure on the switch pulling it away from the
circuit board.
8. Once the switch was removed, I put the cover back on and tightened
up the five screws.
9. Then I slid the base back in the slot it came from and tightened the
four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so
very happy.
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
