How does an internal wireless card "go bad"? unless you got it wet and it short-circuited... but you should really be able to just download the broadcom driver and then the wireless driver. don't rate me on this, but i don't think it's your card, but rather your router. my router has been sucking teabags lately.
Since i dont know if you contacted your service provider to troubleshoot the the inabilty to connect to the interent i would start there and if your service provider determines the aircard is bad then depending on your situation personally you may be able to do a 30 day exchange and if you are past that point you may either be under a 90 day or 1 year manufacture warrenty and your service provider will be able to advise you on how to process a warrrenty claim and if you have insurance and the warrenty is not applicable to your situation your service provider will be able to advise you on how to process an insurance claim and you may have the ability to process an upgrade to replace the aircard and if all else fails you may have to purchase an aircard at full retail price and on a side note i would inquire with your service provider if your sim card could be the cause of the issue to ensure proper solution.
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
