I cannot reboot, the thinkpad is locked. how do i u7nlock it?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Unplug the AC adapter.
Take out the battery for three minutes.
Reinstall the battery and see if your laptop boots.
I hope this helps.
Good luck.
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
1. Power off the computer
2. Remove the DIMM cover on the bottom side of the computer.
3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
4. Under the short-circuit condition, power on the computer and wait
until the POST ends. After the POST ends, the password prompt does not
appear. The power-on password is removed.
5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
1. Power on the computer by pressing and holding F1.
2. Enter the supervisor password. The Easy-Setup menu appears.
3. Click on the Password icon.
4. Click on the Power on icon.
5. Enter the supervisor password and press the Space bar.
6. Press Enter twice.
7. Click on Exit; then click on Restart.
I have IBM T43 notebook and it's power-on lock condition.
I was tried above method #2, but I can't find location of jumper at DIMM cover area.
Anyone knew where is it? or other method?
Get manual on google.com how to remove bios password
