Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My spa drained into my pool - Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Posted by jen_cassity on
joespools200
    Champion:
  • 246 Answers
ONE OF THE DIVERTED VALVE IS STOCK OPEN TO THE SPA OR SOME ONE MOVE THE TOOOGLE SWITCH
Posted on Oct 13, 2009
Drain pool without draining hot tub
Is your spa plumbing tied into the pool plumbing? What exactly are you trying to do?
Mar 18, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
I have a pool with a built in spa and I need to Isolate the spa from the rest of the pool. So I can heat it and not the whole pool. I don't know how to add pics so I will describe the best I can. I have 2...
the actuator at the intake of the pump divides spa intake and the pool intakesmake sure switch on actuator is on 1 or 2 if in pool mode the off should be at spa intake the out inpool postition the off should be to the spa outlet
Feb 18, 2011 | Jandy Pool & Spa
How do I drain my spa?
is this built in spa (integrated with pool) or stand alone above ground spa? If it's above ground, you should have a drain plug along the bottom, possible behind a control panel. If it's an integrated spa, then depends on the plumbing. You may be able to just change a couple valves and drain into pool. Give me a little more info and I can help
Sep 12, 2010 | Flotec Pool & Spa
Spa draining into pool
check should be on spa return line from filter or heater. its 1 1/2 or 2 inch pvc
Jul 13, 2009 | Jandy LAARS VALVE, PRESSURE RELIEF 75PSI...
Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Feb 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Spa drains when turned on
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
Jan 26, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
137 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Marvin
Marvin
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
