Question about Vizio Televison & Video
I have a 48 inch lcd vizio t.v. it is a year old i purchased on line. the dark colors in the picture have green lines through them. i have misplaced my book and remote. how can i get this repaired and for what cost?
    New Friend:
Sorry to say that I don't have a solution to your problem; I just have the same exact issue. I called the tech staff at Vizio and was told that problem is on the "main" board and that the board would have to be replaced. Sounds like telling an auto mechanic that your car is leaking coolant and being told you'll need an engine swap! Sad. My TV's green banding will often go away after a protracted warmup and then work fine until I turn it off again. I'm convinced that it's problem is thermal in nature. This could mean that it has a heat sensitive IC, an intermittant cable or board component connection, or less likely, some software programming issue. (BTW, I run a small fan behind the VIZIO to help it run cooler since it's tucked into a media center.) The repair, if factory done, will probably cost as much as a new LCD TV during the Holiday sales. Sooner or later, I'm going to tear into mine and use a small heat gun and see if I can localize the problem. It's worth a shot, but I don't recommend this to anyone without electronics repair experience and lots of attention to safety!
Posted on Nov 27, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Should I change the T-Con Board?
t-con is my first choice, but failing that, the screen is dead, and the tv needs replacing.
Dec 11, 2015 | Vizio Vf550m 55-inch Full Hd 1080p 120 Hz...
I have a Vizio M701d-A3 with single line across the top half of my screen, it appears over top of the menu when displayed. The line is not black but changes color with the picture. What's the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Feb 05, 2009 | Vizio GV42L 42 in. LCD Television
My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Nov 15, 2008 | Vizio L6 20.1 in. HD-Ready LCD Television
Televison & Video Logo
723 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
