Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
I'VE HAD THIS TV FOR 4 1/2 YEARS-THINK IT'S THE BULB-REPLACE?
Posted by nik2917 on
Sonny Berry
  • Samsung Master
  • 8,617 Answers
The HC-P4752W doesnt have a lamp. Thats a rear projection it has three picture tubes.
Posted on Oct 11, 2009
1 Related Answer
Anonymous
  • 1476 Answers
SOURCE: My Sony Wega KDF-55XS955 TV
julian1390,
That could certainly be your problem. If the unit has not had the lamp changed in the last 3 years it ceratinly would not hurt to do that. Even if this is not the problem you will have a replacement lamp for the time in future when the lamp does go. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will help you do this.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Jun 16, 2011
Screen is losinjg brightness. Seems to be fading and alot less bright. I tghink it is the bulb.
since this is a projection I would say that most likely the bulb is your problem. I also have a projection tv and like every 3-4 years i have to replace the bulb..
Jul 02, 2011 | RCA D61W136D 61 in. TV/DVD Combo
My Sony Wega KDF-55XS955 TV keeps getting a blank screen every 4-5 minutes. I've been told I need to replace a bulb; however, cannot figure out where to locate the bad bulb. Any assistance would be...
julian1390,
hardrocko
Jun 16, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red light solid, green light flashes 10x cycle. no pic/sound
You've got to replace the bulb. I've had my KF-50WE610 for four years. Mine just went out again too. This is the third bulb in four years. The bulbs are expensive too - $100 -$200 each
Jun 11, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
I have a RCA HD50LPW42, Rear Projection tv and my bulb went out after two years is that a good amount of time for the bulb to last. also I want to know about the fan. Does the fan only come on when the tv...
2 years is normal, I`ve seen some fail in 12-15 months, fans run when cabinet interior is hot, they are controlled by temp sensors located inside the set, video-tek
Jun 04, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Re44sz21rd
HI,
All I can suggest is to replace the bulb. I experienced a similar problem after about 2 years viewing when the recommend lamp life was approx 8000 hours (I got to approx 3000 hours). There is a service menu you can access where you can reset the lamp hours time. I have read that if this is reached you must replace your lamp, but you can extended this by reseting the hours.
I have since learnt that a lamp bulb can go at anytime, so it is worth having a spare. Also I have noticed that switching the TV off at the switch (not leaving it in standby helps).
Try this to access the service menu. Holding down the menu button on the remote and the one on the TV for a few seconds. I think the TV needs to be off.
From memory, I think it is option 4 and option 5, then reset the lamp hours to zero
Sep 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Sony wega KF-50WE610 went dark...
If you have not changed the lamp in the 4 years you have had the tv you will need one soon if not now. is sound from tv or receiver, when the lamp dies usually no sound from tv. If you have sound from the tv try unpluging power from wall to reset and try again
May 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
Demonic-2011
Demonic-2011
