Gaggenau EB290 built in oven. After trying to reset the clock due to daylight saving, the trouble code F10 appeared on the LED display along with the "door locked" key symbol. I am unable to open the door, or operate the oven. I have the operating instruction booklet for this oven, but the problem isn't mentioned. Does anyone know which buttons to push in order to fix this? Cheers
SOURCE: Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
SOURCE: Single oven door latch is broken
hi we sell gaggenau parts but we are in the uk [email protected]
SOURCE: My Gaggenau oven shows a
I have the same problem and the technician came out and took the oven out. He couldn't figure out was wrong and will need to contact the manufacturer technician to help him with the diagnosis of the problem. In the meantime, he says it looks like my modem is not working and may not be responding to the commands that would normally remove the key lock after a power outage.
Sorry, can't be reset - you'll need to pay the big bucks to have a technician out to assess, make sure you tell him your model number so that he can do his homework prior to coming out, that way you're not paying alot of money that I had to for this tech to figure things out. He took one hour and charged me $120 with no fix and will have to come back anyway.
SOURCE: lost instructions need help use of rotisserie in my to oven
http://www.gaggenau.com/US_en/service.do
click on link, click on 'all manuals available for download', anew window will open, type in your model and choose the language and manual you require IU is user manual, ii is installation manual.
Hope this helps
