Dirty coils will affect operation. The condenser is hot when operating and as long as the fan is operational you should be fine if dirty coils were the problem.
Eric
If the condensor coils and compressor motor seem too hot, make sure that the compressor fan is turning. This is what removes heat from the coils by pulling room air across the coils.
The fan is usually at the back of the refrigerator down low. If it's not turning, you will need to replace the fan motor.
The fan is working fine. the coils feel cool but the pot is hot to the touch you can only put your hand on it for about 2 seconds,
modle ED2FHEXMQ00
there is no ice build up in the freezer. when i noticed the issue my ice was melting and everything else was defrosting.
have you looked in the freezer for ice or frost? there will be alot of heat from the condensor it sounds to me like the unit is not going in to defrost to thaw the evaparator that is located in the freezer behind the evaporator vent cover to check this you will have to feel or look for ice behind this pannel. if so manualy defrost this unit. there is a temp sensor that could be the cause but to test this sensor that is cliped to the aluminum line it has to be froze and test closed there are also 1-2 heaters in the freezer that have to oam. please give me model for more info
