Question about HP Color LaserJet 2600n Printer
The Color is printing blurred?
When I print a document with color, the color, especially red tones are very blurry. I've tried to clean, calibrate, restore defaults, put in brand new print cartridges -- and it is still blurry. Black prints perfectly clear. Any suggestions??
Posted by heather_mcgr on
Anonymous
  • 81 Answers
Could be down to dirt contamination in the laser scanner
Posted on Oct 12, 2009
Just wondering: my printer's yellow and black toner are both empty and need replacing. Would this cause the printer to calibrate for minutes at a time? After calibrating, I tried printing a document with...
If your going to print in color may it be just red or blue. You really need all of the cartridges for it to work. Because for the printer to come up with those colors. It would need all three colors Cyan, Magenta and Yellow to come up with the any color, in your problem, Blue and Red.
Feb 04, 2011 | Dell 3100cn Laser Printer
Is there something I can clean on my HP Laserjet 2600n. I've done the recalibration and things that are built into the menu system. The colors appear faded, especially red. There's an echo-type of...
Using the REPORTS MENU print the "color supplies status". Make sure everything is good.
Select SYSTEM SETUP. Select PRINT QUALITY. Select CALIBRATE COLOR. Select CALIBRATE NOW.
Check the Transfer Belt(ETB) which is inside the front door. Make sure that it is free of your "racing stripes".
You can use HP TOOLBOX to troubleshoot.
You are using HP cartridges???
Dec 12, 2010 | HP Color LaserJet 2600n Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
HeLp! My HP CM2320nf MFP is printing blurry!
I had the same issue... and found this to finally work after reviewing many sites.
System Setup - Print Quality - Adjust Alignment
Apr 29, 2010 | HP Laserjet CM2320nf All-In-One Color...
Red prints as Orange
If this is magenta being weak (light) on all the things you print (try doing a test pritn, and a configuration page from the printers own menu system). this will be the dirty laser lens/mirrors problem that is very common with this printer.
Solution is either
Dismantle (it IS quite a lot of work, but fairly straightforward methodical screwdriver work) the printer to remove the laser unit. Take cover off the laser unit and CAREFULLY clean the lenses and mirrors. NOTE take care not to disturb the alignment of any part of the laser optics, and be especially careful with the mirrors as they are surface silvered and V easily scratched.
You can find NEW laser units on a certain internet auction site, and also (genuinely) refurbished exchange printers. Both of these two opttions will obviously save time and effort, but be more expensive.
Jan 20, 2010 | HP LaserJet 2605DTN Color Printer
Blurry print on Minolta Bizhub C350
CLEAN LASER UNIT ON THE DOOR U HAVE STICK AND PADS FOR CLEANING
Apr 09, 2009 | Konica Minolta Office Equipment & Supplies
I have Hp color laserjet 2600n -when i print a color document, the left hand side of the page is faded, the middle and right hand side of the document prints fine. Internal documents print perfectly- this...
According to HP if the problem is only when you print from your PC or Mac then you need to reinstall the printer driver. If the problem is also when you print just from the printer, i.e. scanning or test page, then the problem is with the printer.
Mar 20, 2009 | HP Color LaserJet 2600n Printer
Logo prints out blurry
It would more likely be the transfer belt then the fuser. Try doing the calibration 3 times in a row and see if that helps.
Press Select (Swoosh)
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 28, 2008 | HP Color LaserJet 2600n Printer
HP Color Laserjet 3500 Problem
If you are sure the diagnostics show the colours correctly, one thing I would look at is to see if it had a colour profile set up for it.Don't know whether this printer normally has, if it has not I would suggest reinstalling the driver. To check - Start/Printers & Faxes/ Rt click on printer then properties, look under Colour management tab. Pete
May 25, 2006 | HP Color LaserJet 3500 Printer
HP Color LaserJet 2600n Printer Logo
1,088 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
