Nikon Coolpix 3200 Digital Camera Logo
Posted on Oct 10, 2009
The screen is red and dark colors with lines when turned on.
Vizio LCD SV420XVT1A-has a red screen when starting then red bleeding through dark
Got to go to settings to change the color of your tv screen and see if that helps
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
1helpful
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
2helpful
Thin red horizontal lines across screen
While looking at your TV, remove the bottom right speaker grill. There you will find a cover held by a couple of screws. Remove the screws and behind the cover you will find the "focus pack" which is a group of 6 adjustment screws. The top screws adjust (in order from left to right) the brightness of Red, Green and Blue.
What you will do preferably at night (or with the room dark) turn the top left adjustment screw (Red) all the way to the left and then gradually turn it to the right until the point you can see the retrace line and then turn it slightly to the left until the retrace line disappears. That's it! You can do this for all three colors - if need be. These do go out of adjustment every now and then. The 3 screws on the bottom are to focus the colors individually to minimize "bloom" on the screen. It's best to be in service mode on your TV when doing this OR open up the cabinet and cover (with something) the other 2 colors while you adjust the focus of the color you're adjusting.
Good Luck!
S
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
