The right side analog joystick on this wireless xbox 360 controller pins to the left when moved to the left. It sticks in that posistion as if there is something stuck, like the spring mechanism is backwards, making it stay to the left instead of re-centering. Any help is appreciated.
SOURCE: issue with right analog stick - Xbox 360 Controller
I'm afraid I've had the same problem and I can shed a little light on it.
I've tried to fix this but to no avail. I have even transplanted the whole analog stick unit with one from a working controller to see if it will work but I have the same problem.
So, my conclusion the problem is not with the stick itself, but with the microcontroller inside the pad which takes the info from the stick.
I took the analog unit out, and plugged the pad into the computer without it , but STILL the vertical axis on the right stick was pushing up even though there was no input from a stick. It seems to be a fault with the pad, not the analog stick.
