Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T715 Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My aqua quip hot tub turns on the heater starts to heat, gets to 96 deg and then the heater shuts off. i turned the switc all the way up and it still turns off at 96 help please. thanks dustin
Ned C Cook
Level 3:
President:
  • Master 3,433 Answers
  • Posted on Oct 10, 2009
Ned C Cook
Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1436847
Points
9966
Thermostat calibration is suspect
2answers
Aqua Rest AR-150 plug and play hot tub does not heat water
it takes quite some time for your water to heat up their is no heater on the 110v spa heater type ---friction heat recovery ---which means it uses the heat from around the pump and motor the 220v kit has a 4kw inline heater
I have a Jacuzzi J340 Hot Tub. I am having trouble with the heating. When the pump is on, the water circulates just fine. once the heater kicks on, it runs for about 10 seconds, then clicks to OH, and...
make sure the heating element isnt touching the casing inside the heating tube. if its an indoor tub, make sure the filtration cycles are not set to constant. constant filter cycles on an indoor tub will generate residual heat from the circ pump running 24/7, causing tub to heat past 104 degrees
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 • Pool & Spa
I have a century lasar spa motor 177803, I bought it to put into my small hot tub, what heater/controls are compatiable with this pump?
If you are looking for a stand alone heater here are a few options:
Brett Aqualine HT-1
Therm Products 5.5kW
The above heaters only have Thermostat's for temperature control. They also include hi limit & pressure switches, those two are safety devices to prevent an over heat.
OR
A Hydro-Quip CS500 system, can plug into a regular outlet. It also comes with a time clock & air buttons to allow motor control.
Oct 25, 2012 • Pool & Spa
3answers
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
1helpful
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
2answers
Just bought a house with a hydro quip cs 6000
Hey Mike; what is it you would like to know about your hot tub?
Thx
Ken
Aug 30, 2009 • Home
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
