Panasonic Palmcorder PV-GS120 Mini DV Digital Camcorder Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn the camcorder on i get a blue screen with red letters saying push the reset switch so i push the reset switch and when everything comes back up it i get the error screen again
Anasty B.
Level 2:
  • Expert 126 Answers
  • Posted on Oct 13, 2009
 Anasty B.
Expert
Level 2:
Answers
126
Questions
0
Helped
39444
Points
169
Rear operation unit must be replaced
My TV was working and then all of the sudden the screen went blank and now there is a flashing red light that appears. I tried to turn everything off and back on (the universal solution to everything) but...
Hello
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Samsung VP-DC161 DVD Camcorder recording problem...
I have replaced that cam with another one but good. It was a electronicaly problem. Now it's ok. Thanks!
1helpful
3helpful
3answers
PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Must reset the camcorder to power on.
Sony has a fixed repair cost which includes parts. That is where the $211 comes from. If you have a major problem, you win as the boards inside can easily cost more than that. If you have a minor problem, well...
That being said, there are no other symptoms other than the need for a reset? This sounds like a logic problem. The power-on should be resetting the whole camera anyway. I'll look up this model tonight. As far as the shutdown is concerned, this is normal. If the power-up sequence fails (not performing the reset constitutes failure), the unit shuts down to prevent damage. So at least that part functions correctly.
Stay tuned...
Dan
10helpful
2answers
Help,,, camcorder when turn on says "to service " and turns off
after reading the above solution, a few swift taps to the bottom got it to work. I guess it is just be careful, but if it happens - show it some tough love
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
