Question about Jabra BT2050 Bluetooth Headset
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Posted by grovelaw on
Anonymous
    New Friend:
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Posted on Dec 08, 2009
Anonymous
    Scholar:
  • 167 Answers
You can manually put the Jabra BT 2050 into pairing
mode manually. Make sure the headset is off. Press and hold the on/off button for approximately 5 seconds until the LED has a constant light.The LED will flash before the light is constant –
keep holding down the button until light is constant.
Then make sure the device you are pairing with is in "discoverable" mode...
Good Luck
Posted on Oct 10, 2009
Anonymous
    New Friend:
I thought product was defefective...it would just keep blinking 3 times when i followed the instrucions on manually pairing the device...it would not stay solid...martinramos was right on....THE BOOKLET FOR PAIRING IS WRONG!!!!!! follow his advise not sagertronics who just regurgitated the booklets advise...thanks so much martinramos!!!!
Posted on Dec 25, 2009
Hi, i have just set my JABRA BT 2070 however i accidently clicked on LETS FORGET this and now my jabra bt2070 is not pairing ny longer, please help
1. Switch Bluetooth headset off. 2. Press and hold the answer/end button until a solid blue light comes on. Headset in pairing mode. 3. Go into phone's bluetooth options and "search/look" for devices. you should see the headset. 4.Pass code is "0000"
should connect and be good :)
hope this helps
Apr 17, 2011 | Jabra BT250 Consumer Headset
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
How do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Sep 07, 2009 | Jabra BT125 Headset
I have a jabra bt 2050 that will not pair it only flashes 3 times any ideas
YOu have to continously hold the power button, till the LED remains stable...
When you see the light stable, you can search for bluetooth dewvice in your mobile and pair ir..
When it as asks for pair code give 0000...
Now you can switch on your blueooth headset normally and now you can connect directly..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 01, 2009 | Jabra Bluetooth Headset with Adjustable...
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Cant par my jabra bt125
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Jan 15, 2009 | Jabra BT125 Headset
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra BT2050 Bluetooth Headset  Logo
1,852 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Marvin
Marvin
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
