Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the oil capacity of the briggs ans straton i/c 17.5 hp ohv motor
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on Oct 10, 2009
Anonymous
Master
Level 3:
Answers
389
Questions
0
Helped
273519
Points
1274
Approximately 40 ounces. Put in a full quart first, then add about 1/4 of the second quart and start checking the dipstick until you are at the full mark. Each time you add more, let it run down into the engine for a minute or so before checking or you will get a false reading. If your engine has an oil filter and you changed it, figure about 2 extra ounces for the filter
What is the oil capacity on a Briggs and Straton 140cc motor?
the motor should have a dip stick on it and it will be marked with a oil level mark just fill to the mark you will be fine but do not overfill
1helpful
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
Hard to tell how much oil to put in new snowblower ...
www.shopyourway.com > Manage My Life > Questions
Jan 14, 2012 - The manual states that the snowblower has an oil capacity of 20 oz and it ... How much oil do I need to put in my Craftsman model 917.388122 ...Missing: 627804x79a ‎spirit
Where can you get skid plates for Spirit 8 hp 27 Model ...
www.answers.com > ... > Gardening > Lawn Mowers and Garden Tools
Where can you get skid plates for Spirit 8 hp 27 Model 627804X79A snow blower? Where can ... What viscosity oil does a 5 hp techumsen yardmaster snow blowerrequire? My 5hp ... How much hp does a 205cc Briggs and straton ohv snow blowerengine have? ... Take the cap off that nipple and tip back to drain the old oil.
Nov 24, 2015 • Garden
What type of oil is recommended for my Briggs and Straton v twin ohv 20 hp engine?
A good brand of 10W40 like casterol GTX I use it in mine and it prevents wear and sludge . I have been a small engine mechanic for 25 years and use it in all my engines.. try it !
Briggs and Straton OHV I/c 17.5 hp motor. Starter stays engaged. How do I touble shoot the starter or switch?
it sounds like the solenoid is staying engaged. try using a tester light on the starter.
Jul 15, 2011 • Garden
What is the valve clearance on 23 horse brigs &straton intake & exhaust
The solenoid on carb was bad causing reduced gas to motor and low power
2answers
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
3helpful
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
5helpful
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
