Question about Samsung Cameras
Hello, i have a samsung lns3241dx/xxa. it's 3 yrs
Hello, i have a samsung lns3241dx/xxa. it's 3 yrs old. not used much as its in a bedroom. the problem is with the sound. when turned on, there is no "SAMSUNG GREETING BLIP", the picture comes on. you must then turn the tv off & on, usually getting a staticy,cracking sound. if i let the tv "warm up for 5-10 min. i can usually turn it off, then back on. this is when the sound comes on. it's weak at first, then gains volume & normalizes. what's my next step?
Posted by gweigl07 on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Samsung c630
Just bought one recently, and experienced a melt down like that..
What batteries are u using?..
This cam uses lots of power and i started off with 2700 rechargeables, after their 1st charge they emptied fairly quickly, after shutting the cam down for a few mins, they soon picked up again, i was using flash everytime, i guess this was the problem... When my rechargeables started to run down, the cam acted weirdly.... i think ur problem may be because of batteries weakening at that particular time??
Are you aware whether ur batteries were full or nearing empty at the time??
Colin
[email protected]
Posted on Feb 08, 2008
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
Anonymous
  • 3 Answers
SOURCE: Samsung s360
that's because the battery is dead.
Posted on Jul 11, 2008
Anonymous
  • 21 Answers
SOURCE: Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
Posted on May 24, 2009
Cary Leonardt
  • 304 Answers
SOURCE: samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Posted on Jul 17, 2009
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
Samsung RL33SBNS fridge control panel
Hello!
Please check the control panel instruction of the manual: http://manualsbrain.com/en/manuals/1290306/?page=8
Jul 21, 2017 | Samsung Refrigerators
Bottom Plug Leaking Water Tank Bone Dry /Everstar mpk cr 10000btu
you said that it has not been used for 3 yrs then maybe the tube leading to the water drain is clogged. try to clean it
Aug 21, 2009 | Danby DPAC8020 Air Conditioner
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Goes from fully charged to almost zero charge in seconds
HI,
Please make sure the charger is working.I suggest you try replacing it with a new charge and then give it a try.The problem can also be with the battery if it is more than 2-3 yrs old.In this case the problem is with the battery.
So i suggest if the battery is more than 3 yrs old buy a new one and then test it with the old charger and if the battery is not old then replace it with a new charger and try charging the battery.
Let me know the result
Jul 02, 2009 | Samsung BlackJack II Smartphone
The t.v.just went blank while watching it.
Power boards are like time bombs. When it's time is up, it's up. Since it is 3 yrs old, I would buy a new tv. Most TV parts only last 3-5 years anyways. It did a good job.
Nov 14, 2008 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Cameras Logo
93 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
