Question about Canopus DV-Storm-2 SE Plus Ultra Bundle
I have recently changed my motherboard and move on to ASUS P5Q. Now the nightmare begins I,v bought XFX HD4850 ATI graphics card for disply and I simply can't run Adobe priemier pro or Edius wich is bunduled with strom2. I can't see moving video during capturing during capturing in mpegcapture nor seemoving video in Edius monitor. Infact I can see all video on my TV via strombay AV output.
Posted by parthjay on
Anonymous
    Problem Solver:
  • 13 Answers
Hey im a expert
Posted on Oct 10, 2009
XFX 6850 crashes
Had the same problem, video card went bad. Replaced with newer faster model.
ASUS P5LPK- AM IN GRAPHICS CARD SLOT
Yes it should, this motherboard has a PCI express 16X slot, so I don't see why not. The Radeon HD4350 should be PC express as well.
Make my wicked system WICKED. Sound hd issues palit hd4850
try these options:
1. try adjusting the main volume of your digital output(tab) under your hd audio manager.
2. try changing your cable(s).
ATI Radeon HD4850 512MB GDDR3 with
you have to go into control panel hardware and sound, now click on sound, you will see speakers with a green check next to it. on top you will see HDMI enable those and hit test button. this is part of device no worry bout bios or motherboard. Just make sure you use the adapter that came with the video card it will only work with the supplied adapter. Not a dvi to hdmi cable. this will work. i hope this helps and good luck. I can coach you more but i am not sure of your operating system. i was coaching you using vista.
2answers
Is my motherboard compatible with a new graphic card
Being agp3.0, it is backwards compatible so in theory, it should work. With the older system, it may be dangerous. I would find a card that clearly states that it works in x8 (3.0) 1.5v. If it doesn't work it could fry the whole system. If i find a card that works, I'll let you know.
Cannot connect monitor to motherboard
the asus p5q-e motherboard doesn't come with a video card. teh e-SATA-1394 is the serial hard drive connection.
you need to get a ATI video card, since th edriver is ATI, it is much easier tooc onfigure than any other video car.
make sure to get the DVI-D video card.
Canopus DV-Storm-2 SE Plus Ultra Bundle Logo
Top Canopus Computers & Internet Experts
Admin UK
Admin UK
Colin White
Colin White
Mark Ultra
Are you a Canopus Computer and Internet Expert? Answer questions, earn points and help others
