SOURCE: MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
SOURCE: PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
turn off the printer it willsave the setting
SOURCE: Won't print a 4 x 6 print. Paper passes right through printer
Hi-
Double check on printer properties under printers and faxes if 4X6 is selected, then access printer properties as well on the application or program where you are printing the images by clicking File then print option. Make sure Epson is the default printer.
Keep us posted, thanks!
SOURCE: epson r200
turn off and disconnect from computer.
load plain paper.
press and hold paper feed button WHILE turning the printer on.
still no ink on the paper with new genuine cartridge ?
contact manufacturer for repair.
