Question about Kodak ESP 5 Printer
Colour 'washes out' with multi page printing
When printing several pages, each containing 2 colour images, the first page prints fine but second or third page the images lose colour.
Posted by billy_rowley on
Anonymous
  • 68 Answers
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Posted on Oct 13, 2009
Vertical lines
Lines in prints with this machine would suggest a fault with a drum unit. As each toner cartridge contains its own drum unit it is likely to be a particular colour at fault. If the colour is not immediately obvious, I would recommend printing off a test page like the one here:
http://www.refreshcartridges.co.uk/igloo/colour-laser-printer-test-page/
Nov 19, 2012 | Canon Imageclass Mf-8350cdn Color Laser...
Not good colour consistency over an A4 page
I suggest you find a way to align the cartridge. If it contains alignment utility it should give you a better printout. Also check if you have enough ink on your cartridge. Uneven colour usually is due to lack of ink in the cartridge.
Mar 15, 2010 | Office Equipment & Supplies
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
I cant get my printer to print in colour
please use the colour printer ? and you have a colour printer
then your printer job is colour ? your printer cartries is colour & w&w ?
if colour ? then fristime you aply a print and so the print page is ok and so the previue the page in colour job if yes is ok and other no then
print page and in prperty selectand cleck and go immage in colour select the colour and aply the ok and give a print is ok
Sep 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Enlarge and print pictures with a lexmark 6675
You can expand your image to multiple pages, so you can stretch an 8.5x11 image to close to 18x24, by selecting Poster (in the copy menu), and 2x2.
Mar 20, 2009 | Lexmark X6675 Pro Colour Wireless...
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
Wrong colour
This could one of a few fairly major problems. The easiest way to track down the fault is start by replacing the consumables - make sure you install them in the correct positions - it is possible on the C1100 to put them in the wrong places!! Change the toners first. Most importantly the magenta and yellow. Print several pages. Use MS Paint or similar to create a page with all four component colours on (cyan, magenta, yellow and black)in large blocks (see image below) and print them full page. Now look at the print and see if any one colour is missing or has reduced density. If you have a spare PCU you should but that in next. Let me know what the print outs look like and we will progress to the next step.
Aug 13, 2007 | Epson Aculaser C1100 Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Kodak ESP 5 Printer Logo
89 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
