Wixe127 indesit wash machine gets to 1 minute left on wash cycle and just keeps running with 1 minute on display
Posted by al26har on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
If all you are getting is a wash cycle and not a spinning cycle this could indicate a faulty door switch. the machine will not allow a spin cycle unless the door is locked.
Posted on Oct 11, 2009
Display is flashing and cracking noise coming from my indesit wixe127
could b bearings or may b electrics need more info on cracking
Apr 13, 2015 | Indesit Washing Machines
My indesit WIXE127 washing machine digital timer is running slow according to the time is displays for any particular programme. It is adding minutes on throughout the cycle and as a result the wash is...
I would approach the manufactures website and ask them in an email fore advice as this sounds like circuit board fault such as a resistor on the board loosing its resistance causing an ever more problem for you sorry I cant help you further as these boards are expensive to buy the best way is to find a scrap yard and look for the same machine and hope you get a good board replacement for little monies eric
Dec 24, 2017 | Washing Machines
Indesit wixe127 f-08 error
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Feb 07, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Hi i have a indesit wixe127 and when i switch it on it comes up with deno and will not wash wot is wrong with it
I had the same problem with DENO, while we run the wash machine i press start button and step easier(try the start button and click buttons simultaneously until the code DOF) button until DOF code came, after everything went well. [email protected]
Jun 19, 2008 | Indesit Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
