Question about Emerson LC320EM9 32 in. LCD HDTV
32 in emerson none of the codes listed work for set up
Posted by traclg59 on
Anonymous
    New Friend:
I have the Emerson LC320EM1 - try a Sylvania code... Worked for me!
Posted on Nov 27, 2010
Anonymous
    New Friend:
I bought my Emerson LCD tv model lc320emxf last year and the remote has stopped working for no apparent reason. I've tried universal remotes and no codes work. i've tried the 1864, 11864, 864 also and nothing. HELP
Posted on Mar 19, 2011
Emerson 32 inch
. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
2helpful
4answers
Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
Need additional remote codes for emerson tv - codes listed on
Hi if you haven't already, try these codes: -
000, 127 or 141
None of the emerson codes work with my Philips remote
point the remote at the TV while it is on and press the ON/OFF switch for 2-5 seconds when the TV shuts off..... that is the correct code, then lock it in....!!
1helpful
2answers
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
RCA converter codes wont work on new emerson TV
Estos son algunos códigos válidos para TV Daewoo
11661
11909
10013
10092
10154
10217
10451
10556
10623
10661
10672
10865
2answers
Code for 32" emerson flat screen
Necesito una fuente de poder para un TV Trutech de 32¨ favor comunicarse a mi Email: [email protected]
4answers
Comcst remote control code not working
look on the label on the back of your Emerson TV. Read the small print and see if there is a possible different manufacturer that actually made the Emerson TV. Just because it says emerson doesn't mean emerson made it. Also if no luck there try the UL listing code and search that code to the UL listing website. That may help also.
C-Dog
14helpful
5answers
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Emerson LC320EM9 32 in. LCD HDTV Logo
Top Emerson Televison & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
