Question about Sony Televison & Video
How do you tune using the RM826 remote
How do you tune the Sony TV KV-29X5U using the RM826 remote
Posted by richardemsle on
Anonymous
    New Friend:
1. look at the side with the most buttons.
2. select channel you want to set, eg, channel 3 button near top.
2. slide the outer casing down 1cm to reveal 5 extra buttons.
4. from 5 extra buttons, press diamond with arrow button, then plus or minus button to find station, then diamond again to set.
Posted on Oct 25, 2010
Need to tune a trinitron kv-28f65u to a terristrial signal with no remote control, i can access the tuning menu but without the remote cannot press to OK to start tuning. Are there any combination of...
there is only autotune button on the panel which means it programmes all findable channels in serial order. sorry to say there is no other way without remote commander.
Sep 11, 2011 | Sony KV-28FX60 28" TV
I Have a tv sony kv m1400, but i don't have the user manual,so i don't know how to tune the tv.
1. Press and hold down the [White Arrow Up] 'shift' button.
2. While held down press the UHF tuning button (symbol for button is ->).
3. Press + or - to tune up or down the UHF band as required, until the required station is reached.
4. Select a spare Channel Position.
5. Press [Arrow Up] & [UHF Tuning ->] buttons again to store and exit tuning.
You must use the remote control. No tuning is available on TV.
Feb 09, 2011 | Sony Televison & Video
Sony Trinitron KV-27TW77 will not change channels after setting up auto program. Remote or TV will not change channels.
You have not cleared the number of programs tuned in the auto mode,if only one program is tuned than only remote or TV will will not change channels,check by tuning with cable connection with multiple programs,you will get the solution.
Feb 06, 2011 | Sony Televison & Video
Tuning a sony tv model KV 14 TIU SERIAL No.
Have you turned your tv to the av input mode?
Oct 15, 2009 | Televison & Video
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Wii tune in on sony kv 28 fx
sir u can connect both as front n back,connect only on av input n select the av button in your remote once u press u can view the first input then as followa second
Dec 26, 2008 | Sony KV-28FX60 28" TV
Remote control
0000 is the sony code for Sky remotes
Aug 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Channel Programming
Is this an U.S. made tv? or are you using a universal Sony purchased outside the U.S. If it was made here, then you probably have a bad tuner.
Feb 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-21x1u
Press and hold for a few Seconds the 2nd Button from the left on the front of the TV. The auto tune menu will appear on the bottom right of the screen. Wait until it disappears and then check the channels by using the buttons on the remote.
Jan 05, 2008 | Sony KV-27S35 27" TV
Lost remote control
I have been there with my KV-27S42 and lost the remote. I bought one from Replacement Remotes.com, it doesn't look exactly like the other one (a couple years ago the replacement DID look like the Sony and they must have been threatened) so now it looks a little different but is an equivalet and will solve your problem for $18.
Here's the link:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=1473&categoryid=88
Now my trouble is my KV-27S42 quit working YESTERDAY and I think it's going to cost more than it's worth. May have to abandon Sony because I read about a lot of failures.
Nov 17, 2007 | Sony KV-27S42 27" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
