Question about Toshiba Satellite Pro L300 Notebook
I have a toshiba satellite laptop the screen is black
I have a toshiba satellite laptop the screen is blank when I turn it on. I tried hooking up an external laptop but it does not work. Once I turn it on the only way to shut it off is by pulling the power cord or removing the battery. I took out the hard drive and tested it in another laptop and it works. I can hear the fan running and the cd drive will open and close. Any help would be appreciated. Thanks
Posted by kates_hero on
  • Anonymous Jul 01, 2020
    NO model stated no good aNSWERS POSSIBLE
    Satellite what number model.
    the power button works if you hold it down for 10 seconds, Intel rules , intel hard logic in the chipset. if not the power rails are bad.
    the battery is no good, replace them all
    to test the PC run with no huge battery present run on AC power only.
    if the PC works great you learned now that battery huge is NO GOOD, for a fact.
    for sure shorted batteries are evil do not allow old shorted batteries to be inside any home, or they can catch fire, youtube that.
    new PCs now have inside battery fuses ending most fires.
    if the PC is old, 5 to 7 years old the RTC coin cell batter is bad too.
    on super old toshiba' the coin cell is a custom soldered down rechargable battery very hard to replace, done many. custom cells non standard.
Anonymous
  • 591 Answers
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Posted on Oct 11, 2009
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
I have a Toshiba Satellite L305-S5968 and all of sudden it went blank and will not do anything. It's pluged up and the lights on so it works I turn power on a blank screen comes on that says enter password...
To use external display, Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons
also try to go to enter password 3 times. and note given error code.
use this website to try make passcode online by type notted code
https://bios-pw.org
Dec 25, 2017 | Toshiba Satellite A60-S1561 Notebook
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Laptop turns on, Screen stays blank
Sounds like one of two options, it's either a blown out back light or you have a graphics problem. If it's the back light, you should still hear windows boot up and no picture. Try one of two things. Either hook it up to a external monitor or try a flashlight and see if you can see any images when you shine it across the screen.
Dameon R. Gore
A+ Computer Technologies
Clare, MI
Jun 15, 2009 | Toshiba Satellite A135-S2246 Notebook
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Black Screen
hi, try boot to safe mode, check the display properties, settings and the refrsh rate. if not solved, reinstall the graphics controller driver..
thanks
Aug 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Blank Screen
try to press fn and f5 probably the output was set to external video.
Jul 17, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite Pro L300 Notebook Logo
372 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
