Here are two things to try: I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
On remote Press the CLOCK button and within 8 seconds, press the MEMORY/SET button. Within 30 seconds, press the PRESET ( or ) button to select 12-hour or 24-hour display and then press the MEMORY/ SET button. Within 30 seconds, press the PRESET ( or ) button to adjust the hour and then press the MEMORY/SET button. Press the PRESET ( or ) button once to advance the time by 1 hour. Hold it down to advance continuously. 4 Within 30 seconds, press the PRESET ( or ) button to adjust the minutes and then press the MEMORY/SET button. Press the PRESET ( or ) button once to advance the time by 1 minute. Hold it down to advance continuously.
Manual with pictures is here http://www.sharpusa.com/downloads/archives/product_manuals/aud_man_XLMP60.pdf
Did this for the same problem on the PowerShot A570 IS and it worked wonderfully (thanks to other poster): For the PowerShot A 430: Take out the batteries, then hold down the power button for 30 seconds or more, then reinstall the batteries. Problem solved!
images are too bright ㆍExposure is excessive → Reset exposure compensation
● Adjusting LCD Brightness 1. In any mode with the exception of Voice Recording mode, press the MENU button. 2. Press the LEFT/ RIGHT button and select the [Setup] menu tab. 3. Select the [LCD] menu by pressing the UP/ DOWN button and press the RIGHT button. 4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button. [LCD] sub menu : Dark, Normal, Bright 5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Try rechargable NiMH batteries. They are specifically designed for today's technology, and last much, much longer than traditional batteries. It doesn't matter about the brand -- Energizer, Rayovac, Duracell, generic -- I've found that they all tend to last about the same amount of time in my digital camera. But I only use rechargable ones anymore.
Try the following and see if this helps:
White balance setting incorrect.
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
It is possible that the batteries are dead (they might be faulty or too old) even when they are out of the package, though unlikely.
Try another set of batteries, and if these don't work, you'll probably have to send it for a checkup.
