Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Hi, have Kenmore fridg model #106. I was told fridge has water filter. Can it be replaced and where is it? Thanks
Posted by stcdriver on
Kevin
  • 79 Answers
The water filter is that round looking thing at the bottom of the refrigerator on the front grill. I can see it in the picture you provided. Sometimes, in higher end models, there will be a cover that turns and snaps out. Most units just have a place to grab with your fingers and turn counter-clockwise (to the left as if you were unscrewing it), but don't unscrew it. It only takes a quarter turn to disconnect the filter.
Pull out what you just disconnected and you will have in your hand a plastic (or metal) canister that is the filter. Go buy an exact replacement and usually you have to take the "handle" you used to remove it off the old filter and place it on the new filter.
Oh, probably a good idea to turn your ice maker off and block anyone from using the water dispenser or better yet: pull the refrigerator out and turn the water off.
Good Luck!
Posted on Oct 10, 2009
Anonymous
    Problem Solver:
  • 17 Answers
You can buy water filter at http://www.appliancepartsonline.net
Posted on Oct 12, 2009
Age of kenmore refrigerator, model 55061
Kenmore side-by-side Fridge Model 106-59522801 with ice and water filter, serial No. HRY 4657443
May 08, 2012 | Kenmore 22.0 cu. ft. Side-By-Side...
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Our top freezer, kenmore model 106 is dripping water into the fridge from the freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Refrigerators
Does water supply need to be shut off to change water filter on model 106 side-by-side fridge?
no,the solenoid valve will keep it closed as long as you dont activate any controls while the filters off
Sep 08, 2010 | Kenmore Refrigerators
We have a kenmore side by side fridge # 106-53644300. The ice maker quite working. Could this be due to needing to replace water filter?
Probably not due to the filter. Do you get a strong, steady stream of water from the dispenser? If not you need to look at the saddle valve, which is where the refrigerator gets water from the house's plumbing. Try screwing the saddle valve in as tight as you can then opening it up all the way. If that dosen't improve water flow you may need to call a plumber.
If you have a good strong stream of water to the fridge something may be wrong with the icemaker itself. It could also be the water valve on the fridge. Your best bet would be to call a professional.
Aug 07, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Kenmore SbS refrigerator, water dispenser not working
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 29, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
296 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
