The TX-DS575 will switch on then go off, after trying this for a least 15 times the AMP will then stay on. But it works OK, Why does it not stay on, the RELAY on the MAINS input PCB will click on/off.
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
