Both of our car radios are having problems. in one car we keep getting an invalid signal message and in the other car we're getting a signal from the satellite, but there is no sound
Re: both of our car radio are having problems. in one
Have a car audio installer check the setup of you system seem like you have something connect wrong check you get signal you should get sound if unit is not deffective
Jul. 11, 2014 - In order to recoup some cash I sold on my original stereo (Clarion ... that the EQ line is either not connected or its been fitted to the wrong car or ...
The Sentry Key Immobilizer Module contains a Radio Frequency (RF) transceiver and a microprocessor. The SKIM transmits RF signals to, and receives RF signals from the Sentry Key transponder through a tuned antenna ring integral to the SKIM housing. When the ignition switch is turned to the On position, the SKIM transmits an RF signal to the transponder in the ignition key. The SKIM then waits for an RF signal response from the transponder. If the response received identifies the key as valid, the SKIM sends a valid key message to the PCM over the PCI data bus. If the response received identifies the key as invalid, or if no response is received from the key transponder, the SKIM sends an invalid key message to the PCM. The PCM will enable or disable engine operation based upon the status of the SKIM messages.
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
