Question about Xerox 6180MFP/D Printer
Xerox Phaser 6180MFP i have replaced toners
Xerox Phaser 6180MFP. I have replaced toners (magenta and yellow) with non genuine xerox toners, printer gives error message saying it will not support those toners. Any ideas? I don't want to use genuine xerox toners due to high price of them.
Posted by marksurfsbig on
Anonymous
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
  • Anonymous Nov 27, 2011
    I seem to recall a subsequent conversation I had with a Xerox technical person about this and they said that even though the option to use non-Xerox toner is listed in the user guide, the feature was not implemented in the final version of the firmware. It seems the only solution is to make sure the chip on the cartridge is coded properly to imitate a genuine Xerox cartridge.
PrintDocta
    Novelist:
  • 217 Answers
There are a couple of possibilities here.
Is the printer on a 'page pack' contract ?
Are the toners really chipped for the printer you have ?
There are 8 printers (including the multifunction variants as yours is) that take a SIMILAR cartridge.
They vary in capacity and chip. Some remanufacturers don't realise and have been sening out cartidges for these with the wrong chip fitted.
There has also been a bad batch of chips (a while ago now).
The solution is quuite simple, contact your supplier tell them what the problem is (error message etc) and they should be able to check the cartridge in their test printer (a GOOD remanufacturer will have a test printer for each of the cartridges they produce - how could they test their product otherwise !!).
Posted on Apr 05, 2010
  • PrintDocta May 12, 2010
    The non-genuine toner option should indeed be there in the menus system.
    In the Dell variants of the printer (3310cn, 3115cn, 3130cn) you'll find this option under
    MENU
    ADMIN MENU
    MAINTENANCE
    NON-DELL TONER
    It's likely to be in the same sort of place in the Xerox menu structure.
    I've made and sold quite a lot of toner cartridges for these printers, and (apart from a couple with faulty chips), nevver had one back that didn't work in the printer.
    There is also a big question over the legality of forcing the use of OEM toners only. The printer makers obviusly don't have to make it easy for cartridge remanufacturers (and some make it much more difficult than others). Forcing the use of original toners only would be like buying a car and having to use the car manufacturer's own brand of petrol, etc.
1helpful
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Stuck toner xerox phaser 6140
I am sorry I can not help you. I am having the same problem with a magenta cartridge (also non Xerox)I tried disassembling but I could not find my way. For the time being I am printing B&W .
the other replies are not very relevant I am afraid.
1helpful
Keeps asking for ink and it has ink
Try removing, and then reseating the MAGENTA cartridge.
If you replace the MAGENTA toner-cartridge, does the problem go away?
1helpful
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
2helpful
3answers
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Xerox 6180MFP/D Printer Logo
Top Xerox Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
