Question about Toshiba Satellite A135-S4527 Notebook
Toshiba satellite memory stick problem
My toshiba satellite A135-S4527 will not read my sony memory stick duo adaptor.
it appears in the "remove hardware safely" icon on my toolbar, but when i try to run it, the computer doesn't recognize the stick.
  • Toshiba Master
  • 32,281 Answers
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 10, 2009
Can I get a memory upgrade?
Here you go:
http://www.18004memory.com/toshiba-satellite-a135-s4427.asp
Aug 16, 2010 | Toshiba Satellite A135-S4527 Notebook
Memory stick pro duo sony won't read
Files on a flash drive and memory cards in a card reader can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the memory card and flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 19, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Toshiba Satellite A135 S4527 PC windows xp service pack 3 drivers
Try uninstalling sp3 from add or remove programmes in control panel..because some of the drivers are not compatible with sp3
Jun 17, 2009 | Toshiba Satellite A135-S4527 Notebook
SanDisk 2GB micro SD memory stick isn't working in my laptop. I use a Sony Vaio with Vista, it has a digital camera memory stick slot, and pc adaptor slot for micro SDs. I slipped in my SanDisk memory...
Fixed it. All I needed to do was update the software drivers on my laptop. I have a sony vaio, so I looked up the software drivers they had online and downloaded them. After I installed them it worked flawlessly.
Jul 27, 2008 | LG KU990 Viewty
Drivers for Toshiba Satellite A135-S4527
I hate it when people say DOWNGRADE, Vista hasn't proven itself to be an upgrade yet. In order to get the proper drivers, you may have to open the machine and get the make and model of the devices you need drivers for. However, in most cases you don't. Try driverguide.com for the drivers. There you can search drivers by the machine model or hardware model.
Jun 20, 2008 | Toshiba Satellite A135-S4527 Notebook
1024 RAM
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Wireless connection for toshiba satellite A135-S4527 laptop
Hi, there are few steps to allow the wireless network to get connected to the internet.follow these steps
  1. Verify that the Wireless hardware is working (Right click the My computer icon then goto properties then hardware tab and device manager.see the network adpater is corrctly installed.
  2. Then you can check the ip address in the ethernet properties.
  3. Then check the DNS server is connected
if it is not working , i have one web site here you can see the settings and devices to connect.
http://www1.umn.edu/adcs/network/wirelessxp.html
try it and inform to fixya.com
Apr 19, 2008 | Toshiba Satellite A135-S4527 Notebook
type this in your search engine ....
toshiba support-content list
some tittles of exactly what you typed in will display...
click on one and youll be at the download page...
just been there.I'd type the page in for u but its very long as youll see when u get there.
Apr 12, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
383 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
