Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have a digital electronic safe home protection. I have lost my keys and the battery is dead I have had thi safe for nearly 2 years
Posted by neena19 on
Anonymous
1) look again for the key
2) call a lock smith
3) drill the lock
these safes arent expensive , cheaper to drill the lock and replace that a lock smith , but get a quote
Posted on Oct 10, 2009
Anonymous
1) Setting non-hinged side "bottom down" on a solid surface, do the exact following operation:
2) Slam the HINGE SIDE of the safe onto a solid floor (bottom feet onto floor), at the same time applying clockwise pressure to the dial.
This resulted in the GORDON P45891 Safe with Dead Batteries and Lost Keys to open up.
Ironically, the Safe keys were found inside, which seems a poor place to store them. Although, I don't know how to use the Safe keys, should they prove necessary in the future.
Now, replace batteries, reset code (using RED reset button), and DON'T STORE SAFE KEYS IN SAFE!!!
Posted on Oct 13, 2009
  • jpt_36 Jun 28, 2011
    Super master!!! it's excellent solution. does work on my safe box. Thanks a lot
  • puntk
    puntk Apr 04, 2013
    was your safe an electronic grafter gt24?
The batteries are dead in my grafter electronic digital safe and the keys went missing a few years ago. can you help?
The only option is to have the lock picked and a new one fitted if you wish to continue use of the safe
Jan 19, 2017 | Home Security
My keys lost and the battery dead for my electronic/ digital safe ? where can I get help ? I am located in Singapore.
Heat the safe - not too much then try code again. This will help the batteries to recover a bit. Give it a try,
Feb 05, 2011 | Safe International Digital Electronic Safe...
Batteries are dead and I've lost the keys. Its an old electronic digital safe and I have the key number that goes with it. Know where I can get replacement keys or if its cheap enough to have...
Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
Please provide a rating for my help++++Thanks for using FIXYA
Jun 15, 2010 | Safe International Digital Electronic Safe...
Dead battery! CANNOT OPEN SAFE
This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
May 09, 2010 | Safe International Digital Electronic Safe...
The wrong number was input and now we can't get into the safe, we don't have a key for it, and the batteries seem to be flat. What can we do? The safe is an electronic digital safe GX B0709
You don't know the combination code, and you don't have a key? Or you know the right combo code, but the batteries are dead? If you have the right code, and the batteries are near-dead, try the jiggle suggestion...put the safe on you lap, put in the correct combo, and jiggle the safe while turning the latch. Might work.
Feb 17, 2010 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
4,026 people viewed this question
Top Safe International Locks & Locksmithing Experts
Marvin
Marvin
john h
Sheldon Dedek
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
