Question about SanDisk 2GB microSD Memory Card
I've purchased a sandisk memory card to put music on my utstarcom blitz phone. the phone recognizes the memory card but says theres nothing on it how do I get music on my phone?
Posted by dawn_liggett on
Geoff
  • 562 Answers
Check phone manual to see what format the phone uses when it plays music.
You must put the music on the card with the right format.
Posted on Oct 09, 2009
Have Samsung Freeform II. Just purchased a Sandisk 16GB micro memory card. Phone recognizes card and full capacity. Have moved mp3 podcast files to music folder. Can see all files on memory card with...
IN ALMOST ALL PHONE WHENEVER WE USE MUSIC PLAYER IT CREATE A 'MY MUSIC' FOLDER IN MEMORY CARD.IN SOME PHONE IT CAN ONLY READ THOSE FILE WHICH ARE IN THIS FOLDER. SO WHAT YOU HAVE TO IS TO MOVE YOUR MP3 FILES TO 'MY MUSIC' FILE.
IF MY MUSIC FOLDER IS NOT THERE THEN MOVE ALL MUSIC FILE TO FOLDER WHICH HAS THOSE THREE MP3 FILE.MOVE ALL FILE THERE.
NOW YOU WILL BE ABLE TO SEE ALL MP3 FILES IN MUSIC PLAYER.
SAME RULES APPLY TO VIDEO PLAYER.
THANKS FOR USING FIXYA.
Mar 03, 2011 | Cell Phones
I have a UTStarcom Shuttle. I am trying to play to play music
Put a microSD memory card (limit 4GB) in the phone. Take a few pictures and make a short video .Use the phone menu to transfer the pictures an video to the external memory card. Use the media player to watch your recorded video. Try to play music and you will get a no content found message. Now, turn off the phone, remove the memory card and place it into an adapter that will connect to a computer by usb port. Windows should recognize it as a removable drive. If you look at that drive in Explorer you will see 3 folders. Pictures are in my_pix. Videos are in my_flix. Transfer .mp3 files to the my_music folder. When you put the card back into the phone you can play the mp3 files with the media player. Yes, I did this and it works.
Feb 23, 2010 | UTStarcom Cell Phones
I dont know how to put music on my sandisk microSDHC card with ad
There is a white switch on the sd card. Make sure it is not in protected mode.
Dec 25, 2009 | SanDisk 2GB microSD Memory Card
The music in my motorola rival isn't being recognized
I found out a couple things on this. 1) try their web site, it helps. 2) you need 3 folders on your micro sd a) my_music b) my_pix c) my_flix. Their web page has the WRONG NAME...so use the ones above. Drag and drop the MP3's directly into this folder - DO NO PUT ALBUM FOLDERS in there, it doesn't work.
Oct 25, 2009 | Motorola Mobility Rival A455 Cell Phone
I have music on my SD card but it does not show up on my phone.
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Sep 21, 2009 | UTStarcom Blitz Cell Phone
Music from Micro SD card will not show up on "My Music"
check its the right type of music file for the blitz, mp3, wav and so on then send those type of files
Sep 08, 2009 | UTStarcom Blitz Cell Phone
How to move or download a music file to be a ringtone
This option allows you to transfer music files from your PC. In order to use this option, you must install V CAST Music with Rhapsody on your PC. 1. Open V CAST Music with Rhapsody software. Don’t have V CAST MUSIC with Rhapsody software? Download it for free at www.verizonwireless.com/music. 2. Install the device USB drivers before connecting your phone to a PC. USB Cable and Device Drivers can be purchased separately via the Music Essentials Kit compatible with this device. 3. From the main screen on your phone, the SYNC MUSIC V CAST MOBILE PHONE display appears. Your phone should display the message: Connected. Connection may take a few seconds. 4. Drag and drop the song(s) you want to sync from My Library, to your V CAST Music with Rhapsody mobile phone, listed under the Sources tab. Once synchronization is complete, press the END/Power Key and disconnect the USB cable (purchased separately). 5. Under the Music & Tones menu, open My Music to view and play your music. • A compatible USB cable (sold separately) is required for syncing. • Music can also be purchased via V CAST Music with Rhapsody through your PC.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 17, 2009 | UTStarcom Blitz Cell Phone
Says memory full but i hav a 2gb sd card but cant move without error.
In my experience with the Blitz... It has become apparent that it cannot support more than a 1GB card...
Jun 05, 2009 | UTStarcom Blitz Cell Phone
Putting music on nokia 6205 from memory card
1. put card in computer and format
2. put card in phone, take a picture
3. open music app on phone (nothing should show up)
4. take out card, put in computer
5. copy songs to the newly created my_music folder
make sure all song filenames are only the song titles. all other information (artist, track number, album, etc, should go in the IDv3 tag as the phone will read this information).
I have 2 of these phones, and this is what seems to work for me.
Nov 25, 2008 | Cell Phones
SanDisk 2GB microSD Memory Card Logo
94 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
