If the freezer is defrosting , then pull the refrig out from the wall , and remove the bottom rear panel . Check that the compressor and the fan are running . If both are not , then the main control board is bad . This board , is located behind the 8 " X 10 " panel , above the panel you removed for the compressor . The part number is WR55X10656 .
If you have confirmed that the unit is defrosting and the freezer isn't getting cold. Make sure underneath the refrigerator is completely clean and the fan is running underneath the refrigerator next to the coils. If this all checks out then you have a bad compressor or lost of refrigerant due to a leak in the system. One last thing: Is the cooling fan running in the freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
