Im looking to buy an alpine type r 12 and run it off a kenwood 9103d amp but im not sure if i should get the 2ohm or 4ohm version? i know this amp can put out 900rms at 1ohm and 500rms at 4ohms but sum people say it puts out 900rms at 2ohm aswel and im not sure so just need a professional opinion. thanks
If you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know [email protected],com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Posted on Oct 09, 2009
Testimonial: "but wouldnt it just be better to get the 2ohm version of the sub then?"
Well, since an Alpine Type-R can only handle 500 RMS then you may want to stick with the 500 RMS range. I have seen an Alpine Type-R get SMOKED with around 800 RMS to it for around 4 and a half minutes. Here, take a look at a video of something similar to what I sawhttp://www.youtube.com/watch?v=rY8AfOdK4Y4), even though it is the 2-ohm version, the 4-ohm version will take the same amount before blowing. You are confused about the wiring issue, with ONE subwoofer, you can wire a 2-ohm sub down to 1-ohm parallel and up to 4-ohms series and with a 4-ohm sub you can wire down to 2-ohm parallel and 8-ohm series. What you will need to do is get the 2-ohm version(Alpine Type-R SWR-1222D) and wire that bad boy in series to get 4-ohm so you do not exceed the 500 RMS limit for the subwoofer.
Posted on Nov 06, 2009
Apr 04, 2013 | Kenwood Car Audio & Video
Jan 18, 2011 | Kenwood KAC-9103D Car Audio Amplifier
Aug 20, 2010 | Kenwood KAC-9103D Car Audio Amplifier
Oct 15, 2009 | Alpine MRP-M500 Car Audio Amplifier
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
Jun 13, 2009 | PPI DCX-500.2 Car Audio Amplifier
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Sep 16, 2017 | Alpine SWR-1222D 12" Type-R Series...
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
302 people viewed this question
