Question about Sigma 24-70mm f/2.8 EX for Canon
My 24-70mm f2.8 Sigma lens will not autofocus. It
My 24-70mm f2.8 Sigma lens will not autofocus. It used to work but just quite. It will manual focus. Just wondering what to do? Thanks for your time.
Posted by jhbbeery on
Gary Maitland
    New Friend:
  • 117 Answers
Hi
If it is a DF lens thay are to ways to set the AF
first is to push the A/M button on the rear barell
to AF and then slide or pull the manual focussnig
ring you will a mark on the barrel with AF or manual
Posted on Feb 24, 2010
2helpful
How do you make af work on nikon 3000, using a sigma 70-300 f4-5.6 dg macro lens?
Unfortunately, you don't. The D3000 does not have an autofocus motor; it relies on the the lens having one. This particular Sigma lens, unlike its Nikon equivalent, does not have a motor.
Nikon calls their lenses with an autofocus motor AF-S. Sigma calls theirs HSM.
The autofocus of my Sigma lens 18-200mm not working
You have just two choices then as it is not a DIY repair:-
1. Live with it until you decide to upgrade to a better lens;
2. Send it to Sigma for repair.
If you choose the second option, then if you're in the UK Sigma have a fixed price servicing menu, your repair would cost £93.99 on tariff no.6. Pretty cheap compared to a new lens, but expensive compared to just turning the focussing ring on an otherwise good lens.
The choice is yours...
I hope that you have found my answer to be of use, if so then please take a moment to rate it.
2helpful
2answers
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
I have been using a Sigma DG 70x300 lens on my Nikon D-60
This lens has a motor fitted to it to work on a D60 have you moved the A/M switch to M if not the lens is faulty and will need repair
Sigma 28-300mm autofocus problem
You will need the interupter replaced the iris is closed down so the a/f will not lock on
Autofocus not working
If you don't know how to fix it yourself send it to Sigma UK (01707 329999). They are quite resonable charges for that sort of fault. Their website give a price guide depending on lens and fault. Steve
1helpful
Sigma 18 -200 lens with D40x
This lens is NOT compatible as the body doesn't have a motor . £200 wasted
70-300DL Macro Super autofocus problem
It is likely that the lens will need parts. Sigma is not the best for repair parts. Typically, the small nylon gears that control the AF break. It is still a useful piece in manual focus. Repair costs would likely exceed its value.
Feb 17, 2008 • Cameras
Sigma 24-70mm f/2.8 EX for Canon Logo
Top Sigma Cameras Experts
Harrie
ADMIN Canada
ADMIN Canada
Are you a Sigma Camera Expert? Answer questions, earn points and help others
