Through macbook pro speakers sound starts sounding scratchy and after a while goes back to normal. seems to have to do with overall load on the system. tends to happen when there are more windows of different programs open. but also happens with few programs/windows open, which is a bit strange. in bad cases a complete crash with kernel panic happens and computer needs to be shut down. this is ANNOYING!
SOURCE: MacBook Sound Driver Issues
I also had the same problem, did it with the match, it worked in 10 seconds!!!!!! thx
SOURCE: MacBook Kernel Panic
To fix this problem, download and install Mac OS X 10.4.8 from - www.apple.com/support/downloads.
This should solve your problem.
Let me know how it went.
SOURCE: MacBook sound doesn't work anymore.
My MacBook has been formated wt Microsoft windows XP and the sound is could not work again.
Sounds like the cutout switch in the output jack is stuck open, it is a techy fix sorry (at least it is not a board failure)
SOURCE: MAC PRO dual2.3- freezes, gray screen crash,
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
