u did see this after pic below, and you have tried deleted usb controllers in device manager then reboot
can u tell me if, cam lights up/does windows make a connection sound, when usb from cam is connected?
posted by Jordiane on Nov 18, 2007
Report abuse
It says it is unable to find a camera connected to the USB ports. Any idea where I could find a driver to help this or is it another problem?
Have the same problem? Click Here
6 Other Users Have The Same Problem
Comment by Emilie, posted on Nov 21, 2007
The display doesn't turn on when the camera is turned on unless I switch the mode on the dial. The camera turns off when I toggle the zoom.
Comment by
Guest, posted on Nov 29, 2007
Zoom does not work
Comment by
Guest, posted on Dec 27, 2007
I receive the message the software was unable to find an Olympus digital camera conected to a USB port on your computer.
Comment by petedrum, posted on Dec 23, 2007
Same Problem. Tried it on two XP computers, can't find camera on either. Camera lights up when plugged in.
Comment by Kellib, posted on Jan 01, 2008
I'm having the exact same problem with my camera. i can't figure anything out with it and if i plug the usb into the computer, i hit ok for PC and then my computer freezes. someone please please help me figure this out
View All
Best Solution
posted on Dec 24, 2007
Mickoolz
Rank: Apprentice
Rating: 70%, 3 votes
I had this same problem, I'm using Vista on my HP laptop and I managed to correct it. Apparently HP like to customize Vista and when connecting some USB device's they don't recognise them as what they should. A USB mass storage device. You will need to connect the camera to the computer, the camera will come on then click the ok button so it selects PC. Wait until it finishes its search click cancel and open device manager, scroll down and below Network Adaptors you should see an expandable tree with an yellow exclamation mark named Portable Device's --> FE-280/X820/C520 you will need to right click on the FE-280/X820/C520 icon and select "Update driver software". Then select "Browse my computer for driver software" then select "Let me pick from a list of device driver's on my computer" Scroll down till you see "Universal serial bus controllers" then select "USB Mass storage device" in the next window. It should all work fine now! If it still doesn't work try selecting "Portable devices" then select "WPD File system device" --> "Microsoft WPD filesystem Volume Driver".
Hope it helps.
Cheers, Mick
Was this solution helpful? Show your Appreciation by rating it:
