Question about Humminbird Smartcast Rf 35 Dual Display Wrist Sonar
My HUMMINBIRD ADVANCED RSS will not turn on even with a change of baterry. Any help? Thanks
Posted by whatulook852 on
Josh
  • 35 Answers
I work at Cabela's in the Boating/Marine Department, and have had many many many complaints on these units and their inability to turn on, keep running, and in some instances...not turn off. My advice with this is to;
A. Return it where you bought it from and get a Refund
B. If you cant return it, contact humminbird directly...they should be well aware of the problem, and can work through a solution.
These are the common problems with these units. The only Portable Units Humminbird makes that are of a quality design are the 500 Series Portables. Only problem is your gonna pay the price of a full unit.
Hope this helps.
Posted on Oct 16, 2009
Ike Dittmann
    New Friend:
  • 3 Answers
I found that my unit was full of crystel sachets and one had broken and a crystel had loged bwetween the button and the board inturn stoping me from turning the unit off.
Posted on Nov 25, 2009
Menu settings won't save
once you change settings you have to save the settings it will ask you do you want to save these settings push yes
Dec 27, 2012 | Humminbird Fishfinder 570
Depth and speed are reading accurately however the sonar is skipping meaning it reads for a couple of seconds then blank for a few seconds. No visible nicks in the transducer cable everything is secure. ...
My name is Mike. I understand your problem. What I am doing to help you the best I can, is giving you the manual to download in PDF as well as a support number and other information to help you out. Also giving you my direct page to my Services I offer. Thanks SO Much , Mike.
http://store.humminbird.com/media/document/587_597_HD_DI_Manual.pdf
http://store.humminbird.com/products/399598/587ci_HD_Combo
MY PERSONAL MARKET PLACE SERVICES I OFFER
http://beta.fixya.com/users/mc1beanThank You, Again. Please rate my solution for my free help and some nice comments back would be grateful. God Bless, Mike
Jun 06, 2011 | Humminbird 2009 587ci Gps/fishfinder...
Hi. Just wondering how should the transducer for my humminbird 525 fish finder/sounder be installed correctly? Thanks
You can take a picture of the transom of your boat and email it to Humminbird and they will email it back to you where the transducer should be mounted at. Our email address is [email protected].
Joby @ Humminbird
Dec 27, 2010 | Sport & Outdoor - Others
In water less than 5', my Humminbird 565 reads that it is .6''of water
Hi!
If the sounder works in deeper water then try changing the unit to fresh water instead of salt water (or vise-versa). You'll need to switch to advanced settings first (in the setup menu tab), then switch to the afformentioned salt or fresh water (in the sonar menu tab).
Alternatively, switch back to factory defaults as these settings are made to work "right out of the box".
Best of luck!
Mike
Apr 26, 2009 | Humminbird Fishfinder 565 With Transom...
RSS
1) Go to Messaging>RSS Reader, select it and then press More.
2) Go to the Schedule Update, you will see the option "Every Hour", "Twice a day", "Once a day" and "Never". Select the "Never" option.
After your current RSS finish the update, then the next time it wouldn't turn on again until your manually select "Update Now".
YBC (/\)
Jun 04, 2008 | Sony Ericsson Z610i Cellular Phone
RSS
YBC (/\)
May 04, 2008 | Sony Ericsson Z610i Cellular Phone
My smartcast fish finder is only showing the word smart cast on the display
My SmartCast RF 25 was only dislaying "Waiting for Signal" called Humminbird said the problem was the RSS unit. Six month warranty.
Apr 27, 2008 | RIM BlackBerry Pearl 8100
Low Voltage
The power inverter board is most likely starting to fail. The unit should be sent in for factory service. They will change the board and test it out to make sure that another board did not cause the fault.
Jerry G.
Nov 13, 2007 | Humminbird 595c GPS Receiver
Is it possible to make my Humminbird 787c2 to show METRIC unit instead of IMPERIAL?
hi
Did u bought Humminbird 787c2+GPS or just Humminbird 787c2 ?
If u bought Humminbird 787c2+GPS i like to know, do the built in GPS UniMAP work in australia ? i bought one myself. Thanks.
Mar 27, 2007 | Humminbird 787c2 GPS Receiver
Humminbird Smartcast Rf 35 Dual Display Wrist Sonar Logo
2,712 people viewed this question
Top Humminbird Sport & Outdoor - Others Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Humminbird Sport and Outdoor - Other Expert? Answer questions, earn points and help others
