Nintendo DS Lite Console Logo
Question about Nintendo DS Lite Console
DS Charging Diffuculties
When I turn on my DS Lite, it turns on fine, and I check the battery on the top of the top screen. It says that the battery is full, but the DS light is flashing red. I turn it off and then back on. My DS flashes red and the battery is empty. I keep on turning it on and off, but each time one or the other schemes that I had said before has happened. Next, I tried plugging in the charger, and usually the DS light will become orange. The DS picks up no signal that the charger is in. Does anyone have any solutions or knows why this has happened?
Grand Canyon Tech
  • 3,866 Answers
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Oct 09, 2009
Testimonial: "thanks"
Anonymous
Slsll
<script type="text/javascript" src="http://static.ak
2answers
My son's DS lite stopped working while he was playing. Tried charging...no good. Bought new battery...no good. When turning on the charge light turns green then the bottom screen flashes white (like it...
Hello there! First of all let me tell you that your nintendo ds can be repaired and it is not trash... what you need is to get the bottom screen to be repaired ....you can do it sending it to the nintendo repair shop or by doing it yourself by following this youtube guide http://www.youtube.com/user/nintendorepair.
2helpful
3answers
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
My DS lite is turning on then off
How did you break off the charging light?
Anyway, you probably need a new battery. The battery loses it's capability to hold a charge after each time it is charged so all you need is a new battery.
NINTENDO DS LITE POWERS ON AND THEN IMMEDIATELY OFF
The system powers on, then performs a system check. The DS is finding some sort of error More than likely the top screen was damaged. I've been told that the screen that flickers is usually the good screen. The bad one doesn't flicker because it's damaged. You can replace the top screen yorself (if you're fairly handy), or you can pay a professional to do it. You can get new screens from Dealextreme.com for around 10US dollars, with free shipping. You can also find videos about how to change out the top screen on youtube. Hope this helps
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
5helpful
2answers
Nintendo DS Lite won't turn on
My kids did the same thing. What I did to get it to work was to push back on the top and hold it turn it on. If it comes on then turns off after you let it go get 2 rubber bands and put the 1st. one on the top left down to the bottom right. The 2nd. one goes from the top right right to the bottom left. Then keep turning it on while moving the top to find the sweet spot.
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
1helpful
3answers
Nintendo DS Lite will not power up
This can sometimes be caused by the single smt capacitor on the board in the top half that the screen cables plug in to. Try replacing the cap or the entire board.
2answers
Ds lite
Try charging it.
Top Nintendo Video Game Consoles & Games Experts
Aron
David Shaub
Marvin
Marvin
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
