Question about Sony Cyber-Shot DSC-T1 Digital Camera
My T1 is experiencing power problems. I have several batteries and when the camera is plugged in it shows the charge light but the batteries just dont seem to hold power for very long. It seems unlikey that all the batteries have died at once so maybe the camera is discharging them or it is not charging them properly?
Posted by wandera101 on
Terry Herrera
    Scholar:
  • 109 Answers
DSC T1 li-ion batteries goes bad in a period of 3 to 5 years of continusly use (daily). i will recommend to buy a spear charger that charges the batteries without using the camera.
Posted on Oct 09, 2009
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
My video camera (SDR-H18) wont charge...the battery lights up when charging but when i put it in the camera the camera wont turn on...whats the problem?
It sounds like a bad battery. If you have another battery, or a direct power plug for the camera, try those to determine if the camera itself functions. If so, you can safely assume the battery is the problem. If the power plug works but not a different battery, you may have dirty or corroded contacts where the battery attaches to the camera. If changing the battery works, the old one should be returned if under warranty, recycled if not, or you could leave it on the charger for several hours to see if it can complete a charge at all. If not, get a new battery.
Hello, I've had a DSC-T1 camera since 2005 and it's worked great, but now every time I charge it the battery doesn't charge and the camera overheats (to the point where touching it burns your fingers). ...
I suspect the battery is defective and if it is overheating it may have damaged your built in charger in the camera. That could present a fire hazard. I would first try a new battery.
1helpful
Sony Cyber-Shot DSC-T1 Digital Camera, the new pictures show green but old picture are good.
It is known problem of bad ccd imager in DSC-T1 and Sony will repair camera without charges/ free of cost.
Click Sony CCD Imager Support for details.
Virdical light problem
This is known problem of CCD Imager in Sony DSC-T1 camera and CCD Imager will be replaced.
Sony will repair this camera free of cost for CCD Imager problem. You will pay only shipping charges.
The LCD is dark and cannot view object
Its problem of defective CCD Imager in camera and this part need to be replaced.
Sony will repair this fault free of cost. Please click on Sony CCD Support for details.
Thank you.
Defintely getting power, but not switching on.
There are several possibilities. Let's start with the easiest two. First the battery, take it out and try starting up only with the power supply. Then the memory chips. If a memory chip fails it can cause a no start in IBM's. Take the memory out and try it. Then try it, putting them in one at a time. If these don't work, then I'm afraid your problem lies within. Namingly the power management chip on the motherboard. The pm chip controls the power input, and allows such functions as switching between battery and AC, and battery charging. The pm chip can go without warning, and just because it lights and shows charging doesn't mean this chip hasn't malfunctioned. I've had several IBM's come through my shop that have experienced the same problem you're describing. I've also had them with problems like; it will only power with the battery, won't charge the battery, will charge battery and only run with battery shuts down while charging, only power under AC, etc... all pm chip related issues. Unfortunately, the only solution is motherboard replacement.
Battery Charge
Get another battery and try charging it. You should have a second, backup battery anyway. That should narrow it down between the charger and the battery as to which is defective. How old is the camera? It may be a better investment to put the money into a new camera. Also, look on EBay for a new charger if you find that it is the problem. There are many third-party manufacturers of chargers and batteries that work fine and cost much less.
Kodak Z740, wont turn on!
plug it in dc power if you have a docking station the unplug the cord from the dock and into the camerea. regargable batteries only charge if the cameras sitting in a docking station
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Camera is completely dead & wont turn on...
Just the same problem here, anyone a sollution???
Sony Cyber-Shot DSC-T1 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
Rehan Zafar
Rehan Zafar
Are you a Sony Camera Expert? Answer questions, earn points and help others
