Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Frig shutters and makes noise when the cooling cycle shutoff.
  • GE Master
  • 1,606 Answers
The noise , is the internal motor mounts inside the compressor . the motor , is suspended by 4 springs , which will break , either thru rust , or time . If 1 or 2 springs break , the compressor will " clunk " , when cycling off , thru temperature cycling and defrost cut off . The only way to stop the noise , is to replace the compressor . Usually , unless it's an expensive refrig , people will just buy another refrig . This noise , does not mean the compressor will stop working , only be noisy . Would probably be a good garage box .
Posted on Oct 10, 2009
    Scholar:
  • 57 Answers
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
Posted on Oct 09, 2009
Anonymous
SOURCE:
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Kitchen Appliances - Others
My frig is making a loud knocking noise it seems to happen all day on and off and coming from the back of frig plz help
the fan that blows cold air from the freezer to cold storeage area , is going to brake .
Feb 18, 2012 | Kenmore Refrigerators
The dryer ran for two complete cycles. the third cycle the dryer would not start. When the timer was switched it made a humming noise.
That sounds pretty typical of a motor that has tight bearing and shutting off due to excessive heat being created at the motor because of the tight bearings on the motor. What will usually happen whena motor is very tight is that it will run a few minutes (or cycles) and get too hot and shutoff until it cools down and will start then shutoff agian once too hot.Along with it not starting because of the friction of the tight bearing the motor will make a humming noise and may or may not start.
GENE
Oct 17, 2011 | Roper Dryers
Defrost cycle making noise a humming noise every ten seconds or so until cycle is done then no noise
Does this noise come from behind the frig if so remove rear panel and touch the top of compressor, if its real hot (just be careful can burn the heck out of your fingers) then you will need to test the compressor. Let me know.If the noise is coming from the inside of frig at the top then your defrost timer is a noisy one and you should replace it
Sep 26, 2011 | Frigidaire FRT18B4A Top Freezer...
Seems like the top half of the refrigerator is not cooling and the icemaker is not working
What is the temp. of the freezer section?
not cooling means warm. these are the possibilities if you have a warm freezer
compressor not running
freezer fan not running
conderser fan not running
frig stuck in defrost mode
bad thermostat stuck open
no power to the frig.
water valve bad
water shutoff line clogged
these are some of the possibilities if you are not inclined to troubleshoot then you have to call someone if you can check let me know if you think you found the problem and i will tell you how to fix it thanks
Mar 28, 2010 | Refrigerators
MAKES NOISE WHEN IT COMES ON
The way you describe it sounds like noisy compressor valves. As long as it is cooling ok, I wouldn't do anything. If you begin to notice cooling problems, your compressor is probably going to give out.
Jun 02, 2009 | Refrigerators
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Excessive noise when refridgerator shuts off
Remove the rear cover at the compressor and check for loose mounting bolts on the compressor and fan motor.
Feb 21, 2009 | KitchenAid Refrigerators
Refrigerators Logo
256 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
