Heating & Cooling Logo
Posted on Oct 09, 2009
I hope that I can get this problem resolved. Can there be a thread started to help me through this? I will try to keep this as short as possible, I have a Ducane Mod. CMPB050C3A Nat. gas furnace. The problem is it will not fire up. I have gas coming to the main gas valve( Smart Valve SV9520H) According to manual test I get to glow plug (Hot surface igniter) does light for warm up, main valve opens, glow plug,(Hot surface igniter) lights then goes off, main burner should light (but doesn't) and should be sensed by the flame sensor but (no flame) .Can you help me with these three things in question? 1. Main valve (Smart Valve SV9520H), how to test?) 2. Flame sensor?, how to test? 3. Glow Plug,(Hot surface igniter) how to test. I can be reached ([email protected]) if you have any help for me ........ thnks BobO
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Oct 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
2566
Points
24
Say that you have the glow bar (Hot surface igniter) working
if the flame starts make sure you don't trash on the orifice of the burner, you can try to use a piece of wire or someting small to pick on the orifice of the burner, also make sure is not rust bewteen the burners gap where the flame spread to all the burners because if the flame sensor don't feel flame don't stay light up
hopes this help
1helpful
I got a bernette 134d overlocker and the Nr 3 thread keep on breaking. What's wrong?
Most often, it is misthreading. Remove all the threads from the machine. Then rethread each thread in the order specified and verify the thread path is correct for each. Also, when threading the tension mechanism, give each thread an extra little tug to make sure the thread is seated completely.
Oh yes, very IMPORTANT. Always raise the presser foot when threading the machine!!!
FWIW, when a thread breaks, trying to rethread that one thread will not resolve the issue because it is being threaded out of order. If rethreading the one thread doesn't work the first time, just bite the bullet and rethread every thread.
The other possibilities are the tension is too tight, poor quality thread, or a burr somewhere in the threading process of that thread is snagging the thread.
2answers
Thread 1 keeps snapping
Is it possible the thread might be too old? If so, it might tend to break easier than normal. Also if it got wet.
1helpful
2answers
I am trying to sew and the thread keeps clumping up at the bottom.
Try these solutions.
* Re-thread your machine as it may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
2answers
I have a Bernina Aurora 440 QE which was just recently cleaned. I changed the needle but the bottom thread is very loose. I can not get the tension adusted. It is lined up with the rred mark but it doesnt...
Are you saying when you stitch, the bobbin thread lays on the fabric? Possibly the top thread is not seated in the tension disk. Here's something to try:
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start with the upper tension set at the midway point. Tension is correct when top and bobbin threads meet in the middle of the fabric. Keep adjusting the top tension until the tension is where it should be. Tighter top tension should pull the bobbin thread up into the fabric.
If you are still having problems, would recommend taking it back to the technician. They do sometimes make mistakes so don't wait too long since the last service to bring it back.
Have the artista 180 and the thread keeps
Hi, possibly you have put the bobbin in upside down. Try flipping it over in the bobbincase and see what happens. It should turn clockwise when looking at the bobbin and pulling the thread.Check that your upper tension is not too loose. Check that it is threaded correctly.
Hope this helps.
Rick
2helpful
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
I hope this helps.
2 long and 1 short beeps while starting
Here is the Acer home support page for your notebook, with links to technical troubleshooting info that will help you to resolve this problem.
What is your OS? What kind of BIOS? Here is an article to help you troubleshoot the beep codes. Here is a good tutorial that will explain how to update the video drivers. That may be all you need to do...
Look in the Event Viewer and see what error or warnings are reported. If you right click on the id error code you'll be able to get help & support info on the errors there.
Another thing you could try is to run chkdsk (instructions here) to look for corrupt files on your hard drive that may be causing this problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Trouble turning on
Have a look at the Dell online support site available by clicking here
Enter the service tag number if you have it and search for no post, no boot, or start problem and see what comes up. Also search the dell online forum for possibilities...
It's hard to say what could be causing those symptoms without more info, I'm afraid...
My thread in the bobbin keeps getting jammed up
Here are some possible solutions:
1) Try a new bobbin, and if you wind your own, make sure it is wound very tightly
2) Take the bobbin case out and make sure there are no stray threads stuck down there, they can wreak havoc! To do this, unscrew your throat plate and lift the bobbin case out. Then use your lint brush that came with the machine, or another small soft brush and give it a thorough cleaning under there.
Hope these help!
Jan 10, 2009 • Singer 2662
Blanco Faucet Side Sprayer
It may be a result of extreme temperature changes from the time you tightened the shank until the time it broke however this is very unlikely.Typically the shank only needs to be tightened until it is stationary and immovable by normal operating stresses which is a very low torque value. As a general rule of thumb I use finger tight and an additional quarter turn. I once used epoxy and a short nipple to resolve the same issue but I had the advantage of having a pipe threading machine to fabricate the perfect size nipple and used a large washer and coupling to finish it off. If you try a new shank try tightening it as little as possible and I believe this will resolve the issue. Thanks for using Fix Ya and I hope this is of assistance to you.
Top Heating & Cooling Experts
Paul Carew
john h
