Question about Onkyo HTR500 Receiver
Onkyo receiver HT-R530..after cable and speaker hook up = puff of smoke and blinking red light. Will only turn on for 10sec at a time. Whats UP!???
Posted by niles19 on
Jack South
    Scholar:
  • 195 Answers
One way or another, it sounds like the amp has blown. Probably the outpous and/or drivers and such. Perhaps one of the speakers was either shorted, wires touching or hooked up wrong.
Posted on Oct 10, 2009
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Last night I finished hooking up my new Onkyo 7.1 HT-S5200 system. I used three HDMI cable to connect my TV, Blueray, and cable box. I upgrade the speaker wire to 16ga. The system is plugged into a Monster...
Turn everything off but the receiver. If it stays on turn another one on and see if it pops off if not continue. Most receivers have a pause start to prevent power surge. If it continues remove the protector and try the unit alone.
Oct 27, 2017 | Onkyo HT-S5100 Theater System
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Jul 14, 2009 | Onkyo HTR500 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Jan 12, 2009 | Onkyo Audio Players & Recorders
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Remote controller codes
Go to Onkyo's website http://www.onkyousa.com/. rest the cursor over the support button at the top of the page. Adrop down menu will appear. Select owner's manuals. Select receivers on the new page. Select the manual for your model (HT-R530). It is a PDF file. At the bottom of the manual will be a section about the remote with the codes.
Cheers
Jan 19, 2008 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
529 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
