Rheem Heat pump 5 ton heat strip 10KW what
Rheem Heat pump 5 ton+ heat strip 10KW what size breaker in house
Posted by joseph_s_gun on
Jack South
    Scholar:
  • 195 Answers
I would say this is around 75 amps of draw at max for both the compressor and heat units. . Therefore--at least 90 amp breaker, and probably 100 amps for good measure, and at least #4 or #2 wire to the unit.
Posted on Oct 10, 2009
Why is my heat pump tripping circuit breaker continuously?
Probably a weak breaker. I would change it and see if it happens again. If the problem continues call a hvac guy out
Jan 10, 2016 | Rheem 2.5 Ton 13 Seer Heat Pump -...
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Heater not heating enough
Electric furnaces have strip heat inside of them. Depending on the model, size, etc, is how much heat the system can provide. Many times, if the system has worked in the past and started to have problems later, it's because you have lost half or more of your heat strips. They come in different sizes, 10kw, 15kw, 20kw, but ran on different contactors. So if you have a tripped breaker, faulty heat sequencer, etc, you can still have heat, but not the full amount. I strongly suggest any electrical related problems be look at by a qualified technician when dealing with air handlers. Hope this helps!
Dec 08, 2013 | Heating & Cooling
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
My name is Sonny i have a question i just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 and then tempeture ran up 3 degree and stop dose not ran anymore what wrong with that can you help me...
Check temp setting must be +5 degree than room temp and also in heat "mode".
Check heating sensor placed perfectly. If not fix it in it's place. As it's running for 3 degree, your wiring no fault will be there.
Jan 19, 2011 | Heating & Cooling
HOW DO I WIRE A HEAT STRIP IN MY HEIL CENTRAL AIR CONDITIONER ?
Do you have power to the unit for the new heat strips? what size strips do you have? 10kw-15kw.. ect.
If you had heat strips previously, then i will just need to know the size and application.
Dec 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
Heater on my fairly new air conditioner
SINCE YOU SAID AC I ASSUME YOU HAVE ELECTRIC HEAT. IF BLOWER IS ON BUT NO HEAT THEN YOUR HEAT STRIPS ARE PROBABNLY NOT BEING TOLD TO COME ON OR THE BREAKER TO THEM IS OFF. SOME TIMES THE BLOWER IS ON A BREAKER AND THE STRIPS ARE ON A SEPERATE. CHECK ALL BREAKERS. THEN IF STILL NO HEAT YOULL HAVE TO CHECK THE POWER TO THE HEAT STRIP RELAYS . SEE IF THEY ARE BEING SENT A 24 VOLT SIGNAL TO RUN AND THEN CHECK TO SEE IF THEY HAVE POWER INTO AND OUT OF THE RELAYS. IF YOU DO THEN AN OVERLOAD OR A FUSEABLE LINK OR THE STRIPS THEMSELVES ARE BAD. EACH 5 KW OF HEAT SHOULD PULL 20 AMPS . IE 15 KW PULLS 60 AMPS 10KW PULLS 40 AMPS ETC.
Oct 22, 2008 | Hampton Bay HBLG5004 Air Conditioner
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
423 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
